Thread: Anyone?
Results 1 to 14 of 14
  1. #1 Anyone?
    Apr 2009
    Nassau County, New York
    has anyone done or have thought about boring out there gtp
  2. #2 Re: Anyone?
    Jan 2009
    Tallahassee, FL
    I don't think that you can bore the motors out a whole lot. There is a 4.2L stroker kit out there somewhere, mostly in Australia I think.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Anyone?
    Yup...it bores it to 4.25 liters...but the kit is somewhere in the neighborhood of nearly 4 grand. You can do DIY turbo build for less than that...OR...probably a solid low 12 sec M90'ed car.
  4. #4 Re: Anyone?
    Charles City, IA
    I thought it was like 4.6l, but either way its way to much money for what little gains you get.
    SMGPFC Two Nipple General
  5. #5 Re: Anyone?
    Serena, IL
    just did a quick google search and found this, they start at like $2600, and go to 3000+
    Swan Racing Service 3
  6. #6 Re: Anyone?
    Apr 2009
    ok thanks, only reason i ask is because at we school we got to the chapter of cams and pistons and all that and we had to solve equations for boring a 5.0 mustang so i thought bout our cars
  7. #7 Re: Anyone?
  8. #8 Re: Anyone?
    waste of money. just BUY a 4.3.
    Can't...I tried...head pattern is different.
  9. #9 Re: Anyone?
    im saying to use the 4.3.
  10. #10 Re: Anyone?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    How much fabrication, if any, would be needed to put a 4.3 in?
    2006 Grand Prix GXP
  11. #11 Re: Anyone?
    Donating Users blowfishRus6's Avatar
    g.a.
    what about a 4.3 crank in a 3.8???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  12. #12 Re: Anyone?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by blowfishRus6 View Post
    Completely different motor, 4.3 is based off the 350, the 3.8 is it's own beast.
    77 Morris Garage B
  13. #13 Re: Anyone?
    about as much fabrication as it would be to bore out a 3.8 to a 4.2 block. probably less because motor mounts are easy.
  14. #14 Re: Anyone?
    Feb 2008
    Not sure if it helps any, but mine's bored .020" over, and I don't think there was much of a difference between that and stock size. Of course, I can't really tell that well, because I raised the compression to 9.5:1 as well as fully rebuilt and balanced the motor.
    So, unless you're planning on changing to a set of aftermarket pistons and doing a full rebuild, I don't think it's worth it just for the slightly increased displacement.
