Thread: custom fwi build
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: custom fwi build
    Wausau, WI
    because the air/fuel get combusted and the energy used from it is used to push the cylinder back down. The left over stuff is exhaust. Most useable energy in the air fuel are used up before it gets to the exhaust.
  2. #22 Re: custom fwi build
    Eureka, IL
    Yes I know that, but there's actually more exhaust gases than intake, so why does the intake need to be bigger and handle a smaller volume of gas?
  3. #23 Re: custom fwi build
    the bigger the better. this is a roots blower and will take all the flow you give it. that is why im a firm believer of an open cone.
  4. #24 Re: custom fwi build
    Wausau, WI
    It is about pressure. Exhaust systems often are designed for specific backpressures and what not. On the incoming airflow you want as little resistance as possible at all times.
  5. #25 Re: custom fwi build
    Backpressure on a boosted car?
    HA!
  6. #26 Re: custom fwi build
    Charles City, IA
    The piston is pushing all the exhuast out. It is a lot easier to push things than try to pull it in with vacuum.
    SMGPFC Two Nipple General
  7. #27 Re: custom fwi build
    SE Level Member shawnz90's Avatar
    Kenosha
    so right now im have a 3in intake would a 4in make a big diff?
  8. #28 Re: custom fwi build
  9. #29 Re: custom fwi build
    May 2008
    McHenry IL
    lol
  1. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  2. Clean gtp build
    By Davisgtp in forum Off Topic Discussion
    Last Post: 09-21-2009, 06:07 PM
  3. want to build a real custom box.
    By justwhisen in forum Audio, Security & Visual Electronics
    Last Post: 06-17-2009, 10:52 AM
  4. Engine Build
    By ChrisGTT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2008, 04:18 AM
  5. First wash after the new build.
    By Biggie in forum Visual/Body Modifications
    Last Post: 05-10-2008, 09:32 AM
