Thread: Car won't start!!!!!!!!
Results 1 to 8 of 8
  1. #1 Car won't start!!!!!!!!
    SE Level Member hawk611's Avatar
    socal
    I have a 2001 GTP coupe, and i will not start at times,it cranks and all but will not turn on. IT dose this now and then, hot or cold. i even replaced all 3 coil packs, for the reason that at the time that it did not want to start, i checked for spark from one of the plug wires, and there wasn't any spark. but that was not the problem. I need help, PLEASE. Dose anyone know what it might be?
  2. #2 Re: Car won't start!!!!!!!!
    Bastard Reptile's Avatar
    Kansas City, MO
    I'd inspect the crank sensor first, that's usually the first place to look.
  3. #3 Re: Car won't start!!!!!!!!
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    or the module...if u have an advance auto near you they can run a free test on the module to see if its bad....for now reptile is correct...if we r both wrong then its a power problem to the module or bad wires to the sensor from the module
  4. #4 Re: Car won't start!!!!!!!!
    Kansas City, MO
    Who knows if we're right or not, it just seems like a good place to start and go from there.
    Modules don't go bad as often, but they do go bad.
  5. #5 Re: Car won't start!!!!!!!!
    Apr 2009
    ERIE
    thats why im assuming your right...just thought id give hem all the options in case its good..that way hes not panicking or get pissed if he jumps the gun and replaces it with a new one thinking its the only option and it still doesnt work
  6. #6 Re: Car won't start!!!!!!!!
    Kansas City, MO
    Heh....electrical problems will always make you want to pull your hair out.
  7. #7 Re: Car won't start!!!!!!!!
    Apr 2009
    ERIE
    thats why im bald lol
  8. #8 Re: Car won't start!!!!!!!!
    socal
    Do any of u guys have a pic of where the Crnkshft sensor is, or where is it located
  1. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  2. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
  3. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
  4. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
  5. Wouldn't Start
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 09:27 PM
