Thread: M112 Hybrid Questions from ClubGP
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 161
  1. #1 M112 Hybrid Questions from ClubGP
    SE Level Member WillOverkill's Avatar
    Feb 2008
    Because I'm banned on Clubgp, I'll take the time to help inform our community over here about some of the questions presented about the M112 Hybrid from this thread ClubGP Message Forum troubleshooting
    Firstly, I'm a ZZP distributor. After displaying great interest in the project, ZZP allowed me to purchase their remaining Hybrid technology off of them when they discontinued the product. Over the past 2 years, I've been able to experiment with the units and have sold a half dozen.
    Why it works: The real theory that the doubters shown in that thread like Mat Tallman base their opinions on (and I say theory because very few have actual experience with the Hybrid chargers) is that the extension plates used to equipe the M90 housing with M112 components does not allow the outlet position to account for the new rotor size, and that spoils the gains.
    Discuss the outlets all you want, the real drawback of the roots chargers is the inlet. The rotors need to create a vacuum to draw air through the inlet from the air filter, in order to compress it and move it forward. The S-bend of the factory GenIII inlet is a real restriction.
    What the longer rotors do is create increased vacuum to help draw air through the air inlet and to the rotors so it can be moved forward. Despite the outlet position, the Hybrids do move a lot more air than their M90 counterparts in the exact same case.
    How well does it work: I had two nearly identical vehicles built for customers. The first was an 04 CompG with its GenV M90, a ZZP Intercooler, my SBC camshaft with 1.7 rockers, TOG headers and 3" exhaust. The second was an 04 Monte Carlo with an M112 GenIII based Hybrid, 75mm Northstar TB, ZZP Intercooler, my SBC camshaft with 1.7 rockers, TOG headers and a 3" exhaust. Same injectors, I did the tuning etc, basically from the Intercooler to the tip on the tailpipe they were identical cars.
    The CompG ran a 2.55" and produced 14-15psi. The Monte Carlo ran a 2.9" pulley and produced a solid 15psi. A 3" would likely have put it at the same boost levels as the GenV on a 2.55", a difference of .45". The Monte Carlo on its M90 (WHICH USED THE SAME CASE UTILIZED IN THE M112) put out 12-13psi on a 2.55"; the Hybrid to run that boost would have needed to go up to around a 3.25" pulley, a difference of .7" pulley size.
    We were going to dyno both the same day but didn't get finished intime. They raced instead on a deserted road and the Monte won 3 times in a row. Now I was a big fan of my customer's CompG setup, ran very strong, but the Monte was a solid winner when the two raced that day.
    Can the Hybrid be used in a GenV M90 case? Has this been tried?
    Yes it has, two GenV based M112 Hybrids were produced and tested, one is on my own personal vehicle
    The other is on a good customer of mine's GTP which produced 386whp in street trim on pump gas.
    They work well but the difference wasnt as big as I expected. The straight inlet on the GenV works wonders for the M90 rotors ability to draw air into the rotors and is beneficial to the M112 as well but not exponentially as much.
    A GenV M112 produces the same boost on ~.2" larger pulley than its GenIII counterpart. In order to best take advantage of the difference .2" pulley allows, a lower compression stroker motor, an overly large camshaft or perhaps the new ZZP aluminum heads would need to be utilized. It isn't on my vehicle with an L36 high compression block, modest camshaft and consistent street trim and pump gas, but it's still a lot of fun.
    Are these available, how can I purchase one?
    Although it says on our website that we are machining the components required, truth is we may discontinue our use of the Hybrid technology. Simple fact is we've had to jump from machinist to machinist without any reliable source for having the plates made; many of our projects have been shelved for this reason.
    The current strength of the Canadian dollar also makes it cost prohibitive for us to manufacture anything north of the border for resale back to the American market; anyone manufacturing in the US has significant cost advantages.
    Core components are also becoming older and harder to find in good shape. We use M112s specifically off of Ford Lightning and Mustang Cobra applications because of their snout lengths. These vehicles weren't plentifully made, and while owners loved to swap out their low mile M112s for Whipples and put them on ebay, we see much less of that these days as those cars age. So cores are going to become potentially cheaper but will require rebuilding.
    We did sell a set of plates to a customer who decided to reverse engineer the plates and resell them himself. He can be found on these boards as well as clubgp. Whether he proves to be a reliable source for Hybrid technology, we'll let you guys find out.
    I do know who has the skills and resources to fabricate the parts needed, and that's TrannyMan. We'll be sending TripleEdgePerformance a set of plates, and if Dave is interested in the project we know he'll be a reliable source, and as an affiliate of ours he'll have our support.
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  2. #2 Re: M112 Hybrid Questions from ClubGP
    chicago
    on your web site you said it's best to have both the ic and M112 hybrid install for better gain. what if you only have the M112, can you get good result? both of the kits are over $1k that's a big chunk of money to spend.
  3. #3 Re: M112 Hybrid Questions from ClubGP
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by WillOverkill View Post
    Because I'm banned on Clubgp...
    What a friggin' joke clubGP is. I'll resist the temptation to rant. That hybrid looks hardcore under there.
    That sucks someone it stealing your product. Did you have a patent?
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  4. #4 Re: M112 Hybrid Questions from ClubGP
    Oklahoma
    Will, what great information this is. Im giving it five stars and Im stickying it for now. Perhaps we can get this into the How To section or if we ever do a FAQ section we can put it there too.
  5. #5 Re: M112 Hybrid Questions from ClubGP
    Wichita, KS
    What another let down by the "other forum". Glad "those bad apples" are just staying over there, and not making it over here to where things can be discussed politely and professionally.
    Nice job on the project, and advancing it into the future further.
    Will I give up my GenV yet? Nope.
    ~F~
  6. #6 Re: M112 Hybrid Questions from ClubGP
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    What does this say for me?
    I'm running a 2004 Comp-G with a 3.4 Pulley
    I see high 14PSI Boost with my M90
    I'm running cat-less, Pace Setters, 3" DP, Stock Resonator, Pipe, and Muffs
    I think there is more to the boost than what we see with the M90 vs M112
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  7. #7 Re: M112 Hybrid Questions from ClubGP
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Keep in mind the cars that Will referred to both have an intercooler which will drop a few lbs of boost, cam and 1.7 rockers which will drop boost down a substantial amount more.
  8. #8 Re: M112 Hybrid Questions from ClubGP
    Feb 2008
    Rkrd, IL
    I guess that's the "More To The Boost" I was guessing at...
    Those would be future mods I'm still clueless about,
    I thought you couldn't run Rockers with a Cam?
    This is why I left CGP, needed more places to get info/answers!
  9. #9 Re: M112 Hybrid Questions from ClubGP
    Fort Wayne, IN
    Will has his own cam grinds made for him, the SBC cam is a great cam and there was head room left for more lift on better heads and using a full roller 1.7 rocker completes the package. With stock heads using a decent sized cam with rockers is not going to work because there isnt enough clearance between the retainer and the valve seal. On ported or reworked heads either the guides get turned down for more clearance or LSx style valves are used, what ZZP uses, and this gives plenty of clearance between the retainer and valve seal.
  10. #10 Re: M112 Hybrid Questions from ClubGP
    chicago
    so this won't work with my set up? Will, i like your black color engine bay. you have pic of the monte engine btw?
  11. #11 Re: M112 Hybrid Questions from ClubGP
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Dang I was hoping to get in on the m112 action before it was too late, oh well maybe dave will have time to make them or something.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  12. #12 Re: M112 Hybrid Questions from ClubGP
    SE Level Member TheRealKoop's Avatar
    Lima, Oh
    Awesome information, answered alot of questions i had floating around. Ive always wanted a hybrid, but the cost kills me. Im a cheap ass and buy everything used. Scrubgp is garbage.
    97' GTP- HAI| 160| N*| Ported Blower| 2.55"|
    S2 ZZp IC| LIM| Heads| 50#| XP| Pacesetters| Flow40's
    AL 103| S2 Volt Booster| Alt rewire| FP rewire.
    Built Tranny| Poly Mounts| 3.69's| 3000 stall.
    Walbro 255|AEM WB| Powertuner.
  13. #13 Re: M112 Hybrid Questions from ClubGP
    Feb 2008
    I was surprised about Clubgp. I tried logging in around Christmas time, "User Doesn't Exist" or something to that effect.
    We didn't have a patent, neither did ZZP, they were the only ones that could have applied for one. I simply wanted to built some fast cars and had the opportunity to take over the project from them.
    Here are some more M112 Hybrid pictures:
    An M112 I sold NemesisGTP for his beautiful vehicle
    An M112 on the Monte Carlo I mentioned
    The first M112 Hybrid I put together on a sponsored vehicle of mine
    And that same car again with the other GenV based M112 Hybrid that was produced, sitting on a fresh motor I built him (don't mind the missing pulley, this was after a near all nighter to get his new motor running so he could attend the show'n'shine)
  14. #14 Re: M112 Hybrid Questions from ClubGP
    That sucks. Canada should have patents too that you could apply for. Just wanted to see that you got justice and could wave a lawsuit under the nose of the guy who is trying to copy them.
  15. #15 Re: M112 Hybrid Questions from ClubGP
    SE Level Member Silver_Intercepter01's Avatar
    Hi everyone. This is my first post and I'm also the guy who started the discussion on CGP. Will I'm sorry that you were unable to post in my thread but I'm glad you decided to address some of the concerns in this one. I do have a few more questions if you don't mind.
    First off can a 1999-2003 lightning/harley m112 snout/rotor be used or do they differ from the 2003-2004 cobra m112? I see that the inlets differs...
    Second question is would the M112 Hybrid work for L36 drivers with the ZZP SS m90 kit? It seems to me that you would only need a longer belt to run the M112 from the relocated ALT and you'd be all good. But of course I'm not sure. Any opinions? thanks for your time! I'm really glad that I was able to ask you questions directly.
  16. #16 Re: M112 Hybrid Questions from ClubGP
    Feb 2008
    The lightning/harley M112 snout and rotor guts can be used yes, they are identical dimension to Mustang Cobra M112s. I prefer the Mustang cores however, the rotors have a better abraidable coating (like our GenV M90s), while the Lightning units have the older epoxy coating (like GenIII M90s).
    The M112 Hybrid is really underutilized without a fullsize intercooler, which I understand can't be done on the SS M90 kits correct? Similarly on an L36 block with higher compression, you may not be able to run enough boost to make it worthwhile.
    Where the Hybrid or a regular M112 really shines is with cars that run sub 2.8" M90 pulleys, as beyond that the M90 starts to lose efficiency in a hurry. By spinning slower to create the same boost level, the 112 is noteabley more efficient.
    Even on my own CompG with heads/cam/IC and a GenV Hybrid, I run an L36 block and I keep the boost around 10-12psi on pump gas, so the Hybrid is being somewhat underutilized in my daily driving but L36s don't like too much boost on pump gas. I can however pour in a can of Torco, up the boost to 16-17psi on no knock and the car is STUPID fast, I couldn't do that on an M90, I'd barely get 12-13psi even out of a GenV M90.
  17. #17 Re: M112 Hybrid Questions from ClubGP
    yeah, you can only use the SS IC with the SSM90. I don't plan on taking my car anywhere near sub 3.2 when I go FI. Does this mean I should just forget the hybrid all together cause the stock M90 can take me where I wanna go? Honestly I just wanted the hybrid to be different (impala owner) and because it looks sick, lol!
  18. #18 Re: M112 Hybrid Questions from ClubGP
    Oklahoma
    The more I hear/read you talk about the hybrids, the more I wish I could get one.
  19. #19 Re: M112 Hybrid Questions from ClubGP
    Moore, Oklahoma
    Nice info Will! Keep it up...
    Shawn W. Larsen
  20. #20 Re: M112 Hybrid Questions from ClubGP
    Never Never Land
    Let's get this out of the way..this thread is way old. BUT, is there any chance of the "spacers" ever being made again?
  1. just got my hp tuner...questions!!!!
    By TDCRacing in forum PCM Tuning
    Last Post: 02-27-2008, 08:40 AM
  2. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
  3. New guy with questions
    By chuy53511 in forum Introductions/Noob Questions
    Last Post: 02-03-2008, 07:20 AM
  4. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
