The tune will reduce kr a ton. You are more than likely running lean and knocking because of that. If you have some one tune your car they can fix your fueling issuses and your car will run a lot better. Didn't you say your dad has a heavily modded 3.8? You should really read some more about what you are doing. Changing the plugs is not too bad. Rock the engine forward to get to the rear.
