Just slowly loosen up one of the fittings that connect the fuel line to the log then with a rag under it. If you go slow you will be fine.
So i finally got the motor out late late last night and started the tear down. Noticed my exhaust valves were a burnt orange on the back head and on the front head the exhaust valves were burnt orange and a little white. My lifters and pushrods were fine. No sign of wear or anything. The pistons have some weird grime like stuff that looks to be burnt onto them. Gonna drop the rest of the oil here a little later. The water pump was definetly going out so luckily i picked up that Electric Meziere Water Pump from UR LOSN. Gonna pull the cam and everything else out later on as well. Probably gonna take the block and have that cleaned and what not. Couldnt i just take a steel wire wheel to the pistons to get whatever the coating that is on top of it off? Will upload all the pics to photobucket and will have them up a little later as well.
