Thread: What should I do??
Results 1 to 20 of 25
  1. #1 Re: What should I do??
    Jan 2009
    Michigan
    depends on how you drive it. i know someone that has an 02 with s1x, gen v, togs, and is still running stock tranny. car dynoed 330. car has ~85k miles i believe.
    he did tell me that its showing wear but still goin. so you may get away with stock for a while but if your gonna be puttin track passes on it and are a "spirited driver", ide look into gettin at least the hard parts that fail (you already have 3.29's so thats good). how many miles on the car?
    edit: my trans totally went out at 127k miles. at the time it had headers, 3.4, and some other stuff. dynoed 238. so its a hit or miss, just plan on puttin money into it to be safe. again, if you can do the work yourself you can get a trans while yours is still in good shape and sell yours to get some of the money back.
  2. #2 Re: What should I do??
    SE Level Member streetsmart's Avatar
    Apr 2008
    Red Lion, PA
    the tranny has 78k on it and seems to be in great shape. I believe I will do most of the work, but how hard would the headers be on this? That scares me a bit because there doesnt seem to be a ton of room.
    i will talk to prj, but do yall know of any other sites besides the ones i listed(zzp, 3800performance, pfyc)??
    thx again!
    it looks like i will start with the CAI, pcm, 3.5 pulley, cam, rockers, headers and perhaps the electric exhaust cut out (i already have the 180 tstat and plugs and wires.) it appears i should be pushing around 330hp or so at the crank.....???
    01 GT Black 2 DR
    98 GTP Black 4 DR
    04 Comp G Black 4 DR
    I just can't seem to get my fix!
