I have a Stattama kit from zzp. I am running a T72 turbo with the supercharger (3.4 pulley on the s/c right now). The supercharger will give power off the line up to about 6psi, and then it will bypass and the turbo takes over. For the street, this is a nice setup. I am limited to 15psi right now because I am still in the process of installing a second W/A intercooler. After that gets done, I hope to push closer to 20psi. Still, at 15psi and 15 degrees of timing, this thing moves. I ran the 12.69 with stock heads, stock cam, and stock trans. I have since upgraded the trans to 3.29 with 1" chain, but haven't made it back to the track.
There are a few other people running twin-charged as well. The real advantage to twin-charge is that you can run a bigger turbo like a 70 or 72, and not have lag.
Looks sweet. I wanted to keep the s/c til the turbo spooled up. but is it worth it(money wise) or would it jus be better to dump the s/c and jus go with the turbo?
If you run with a smaller turbo like a 61 or 66, you won't need the supercharger to help it spool. There is very little lag with these turbos, and they are easily going to get you 400whp if setup right.
2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
whats the max boost that the 66 can push? Because my goal is to get into the mid-low 10's within a year or 2. Would the z7 kit work or would I be better off with the stattama kit.
skip a twin charged setup and go straight to big turbo setup. thats the only way youre going 10s in this car. even then youre pushing your luck. 10s is REALLY fast for us.
