the way to go for louder whine is to get more mods. i know a 2.6 will whine like a banshee, but to get there you need a metric **** ton of engine work.
Why does everyone here think it will help with performance gains? It does nothing for performance AT ALL except make the blower sound more audible at idle. This is the stupidest idea ever. And you can't weld the case either...it might warp it...so goes "explore" your ideas to make it work...and we'll run a non-ported GTP vs. a GTP with the slots filled and it won't make a ****s lick of difference. Now if you care to dyno your car before and after on the same dyno, same mods minus the slits filled, AND same air temp...and you make more power...then I'll laugh...and say something was wrong with the dyno. /This Thread.
I did think about it. And I am just tired of hearing all the ridiculous claims in how it helps you out. Show me some hard evidence...not much to ask I don't think. I know you know your sh*t that is why I am saying this. Provide me something and I'll make sure not to knock the idea anymore except it is still a dangerous deal with the epoxy IMO.
You know, this has gone back and forth on every site for blown cars that I've come across, all with no hard numbers either way. What I have seen more than once are statement from people inside eaton that the holes are there to reduce sound by allowing some backflow. Feeding already compressed, heated air back into the rotors to be compressed and heated again can't be a good thing for efficiency, can it? It sure as hell isn't going to be a seat of the pants difference, I'm not arguing that.
Then again, we're screwing up the efficiency by putting on a smaller pulley anyway, so who knows.
providing temps and humidity are relatively the same.......yes
Doesnt matter either way, its just the thing to do when you port a blower.
All the work done to the blower can be done with a router and a die grinder.
And now for today's episode of "As GPForums turns".![]()
