As soon as you get the valve covers off, clean the gaskt grooves, put about 6 tiny dabs of RTV spaced out in the gaskets grooves and install the gasket. This will allow time for the RTV to setup for a bit and hold the gasket in place when installing the covers later.
Make sure you clean out the rocker bolts holes. I don't have an air compressor so I used Q-tips to get all of the oil and metal shavings out.
Assembly lube on the rocker pivot points, valve and pushrod contact surfaces.
Clean the vc to heads mating surface.
properly torque the rocker bolts and vc bolts. Blue (service removable)loctite threadlock
rocker bolts
stock 11 lbs ft + 90*
ZZP reusable 25 lbs ft
PRJ 30 lbs ft - PRJ recommends red locktite (service removable)
VC bolts 89 lbs in... Inch pounds
