Thread: Replacing SC coupler sealing question?
Results 1 to 2 of 2
  1. #1 Replacing SC coupler sealing question?
    Feb 2009
    NE
    OK, so I got the snout off but also noticed the intermediate section that supports the passenger side of the rotars/ bearings broke loose in the process. I note there is no way to get this off it apears and it has a sealing surface to the SC rotar housing. What do guys do when putting this all back to isure the intemediate section and main housing seal is good?
  2. #2 Re: Replacing SC coupler sealing question?
    Bastard Reptile's Avatar
    Kansas City, MO
    The rotors to the housing doesn't really need any sealant. However, the snout to the rotors needs to be sealed with an anaerobic gasket maker. It looks like a jelly, and most of it will squeeze out of the joint, just wipe it off and torque it back down.
  1. Sealing off balance shaft oil hole.
    By chico in forum How To Write-Ups/Tech Tips
    Last Post: 08-09-2009, 11:22 PM
  2. question on when replacing the LIM or what size tap bit for t-stat housing?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2009, 12:52 PM
  3. Which coupler?
    By karkrazy1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 02:40 PM
  4. Corner Sealing
    By J_Man55 in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:04 PM
