When changing the LIM, is it best to drain the coolant from the radiator or wherever is needed first, then after the LIM is done do an oil change? Also is it best to get another LIM gasket set installed? Im using the aluminum LIM, but aside from the orange rubber gasket that would need replaced what about the aluminum pieces?
right now one of my thermostat bolts, the left side, the inner threads are stripped/warped. i need to either get another LIM or get a tap bit and retap the threads in there but dont know which to use. anyone have a spare t-stat bolt that also has a tap set that can tell me what i should use? right now im leaking a bit of coolant and currently applied some black rtv to hold it in but its bene slowly leaking lately. thanks in advance!!
