Thread: Vibration damper removal tips? (solved, has part #'s & links to correct pullers)
Results 1 to 7 of 7
  1. #1 Vibration damper removal tips? (solved, has part #'s & links to correct pullers)
    Feb 2009
    NE
    I need to replace the CPS for the phantom no start issue soon. Any tips on a puller to get/ where to get the one that works for this application? (on supercharged GTP)
  2. #2 Re: Vibration damper removal tips?
    get one from autozone or something, but youll have to use different size bolts/washers to make it work. im not sure of the thread, but its a fine thread 1/4" bolts about 3" length.
    when you get the crank bolt out, toss a stubby (short) 3/8" extension in the hole it came out of to protect the threads from the puller.
  3. #3 Re: Vibration damper removal tips?
    Feb 2009
    NE
    found it. Called AZ and asked for manager. He knew exactly what I needed. Said it was a loaner tool you pay for and bring back and get 100% of your money back if it is all there. Here is the link to the AZ part #. AutoZone.com | Harmonic Balancer Puller
    Also a link to another tool place with exact same part # and pic. OEM Industrial 27019 - Harmonic Balancer Puller Set
    thanks all.
  4. #4 Re: Vibration damper removal tips?
    Feb 2009
    NE
    OK thanks. I was in autozone a week ago and pickup up the sensor and they said they did not have a vib. dampner puller? I will try them again.
  5. #5 Re: Vibration damper removal tips? (solved, has part #'s & links to correct pullers)
    Banned - Busted For Scamming
    Feb 2009
    Thats the standard tool, but you need different bolts, none included will work on this motor. You need these bolts:
    https://www.zzperformance.com/grand_...=339&catid=111
  6. #6 Re: Vibration damper removal tips? (solved, has part #'s & links to correct pullers)
    thats lame how they dont even tell you what bolts they are. i used 1/4" x 3" fine thread with some washers. still have it in my tool box for when i want to pull it again.
  7. #7 Re: Vibration damper removal tips? (solved, has part #'s & links to correct pullers)
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    i just use there three jawed puller. never had a problem before using one and if u strip the threads..oh well...you aint paying for it.
  1. Vibration
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2009, 02:52 PM
  2. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  3. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  4. ATI Super Damper - Anyone know the torque specs?
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 05:15 PM
  5. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
