Thread: Vibration damper removal tips? (solved, has part #'s & links to correct pullers)
Results 1 to 7 of 7
  1. #1 Re: Vibration damper removal tips?
    get one from autozone or something, but youll have to use different size bolts/washers to make it work. im not sure of the thread, but its a fine thread 1/4" bolts about 3" length.
    when you get the crank bolt out, toss a stubby (short) 3/8" extension in the hole it came out of to protect the threads from the puller.
  2. #2 Re: Vibration damper removal tips?
    Feb 2009
    NE
    found it. Called AZ and asked for manager. He knew exactly what I needed. Said it was a loaner tool you pay for and bring back and get 100% of your money back if it is all there. Here is the link to the AZ part #. AutoZone.com | Harmonic Balancer Puller
    Also a link to another tool place with exact same part # and pic. OEM Industrial 27019 - Harmonic Balancer Puller Set
    thanks all.
  1. Vibration
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2009, 02:52 PM
  2. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  3. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  4. ATI Super Damper - Anyone know the torque specs?
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 05:15 PM
  5. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
