Thread: Minichopper6hp(Logan)'s Intercooler
Results 1 to 20 of 82
  1. #1 Re: Minichopper6hp(Logan)'s Intercooler
    Banned - Busted For Scamming
    Feb 2009
    Silicone gasket should solve it.
  2. #2 Re: Minichopper6hp(Logan)'s Intercooler
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Alright so i took the supercharger back off again and swapped both top and bottom Supercharger gaskets with new felpro ones and still no fix. i have a bad leak coming from my thermostat housing and that just had a new thermostat and the o-ring that goes in it. Ive bled the system using the gold set screw that is on top.
    Minichopper6hp: Im on my to get that silicone u were talking about to do this. Sounds like it will solve the problem.
    Silverstreak: Thanks for the vid. Thats exactly what the squealing sounds like but not constant.
    Reptile: Should i be running a breather with this setup? I am running one but should i not be is basically what im asking?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. Logan
    By logands in forum Visual/Body Modifications
    Last Post: 10-24-2008, 09:39 AM
  2. zzp intercooler
    Last Post: 08-31-2008, 06:14 PM
  3. intercooler?
    Last Post: 08-04-2008, 12:53 AM
  4. SS intercooler ?'s
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2008, 12:11 AM
