The squealing is usually associated with not having a good seal on the SC gasket. If you have a spot where the old gasket wasn't cleaned off, then it will cause the new gasket to vibrate and make a high pitch squeal or shriek. It's almost impossible to track down with your ear, but if it goes away when you open the throttle a little bit, that's probably what it is. When in doubt, check everything.
