Thread: Pulley size vs. SC vs. boost
Results 1 to 16 of 16
  1. #1 Re: Pulley size vs. SC vs. boost
    SE Level Member porshuh's Avatar
    Jan 2009
    Northern, VA
    Quote Originally Posted by JoshMcMadMac View Post
    The SC does not have a clutch. You do not get boost because of the "load" on the engine. You mash the throttle, you force more air into the engine, putting the super charger to work. Ease into the throttle, less air, nothing for the supercharger to do.
    See, I just don't get that.
    Say you are driving at 5,500rpm, just cruising at this rpm so there is very low load on the engine. The SC is spinning just as fast as if you were WOT at 5,500rpm and making full boost. So with the SC spinning just as fast and making no boost, if there is no clutch of any sort, where is all that air from the full speed SC going?
  2. #2 Re: Pulley size vs. SC vs. boost
    SE Level Member Robotech's Avatar
    California
    Quote Originally Posted by porshuh View Post
    All what air? Regardless of how much that supercharger is turning think about the throttle body. It regulates how much air makes it to the SC. At cruise or low throttle the throttle body is barely open thus not much air is making it into the supercharger. The output of the supercharger is very little because it isn't moving a lot of air...less than the vacuum created by the engine naturally. Because of this, there is a negative pressure (vacuum) in the Lower Intake Manifold and this keeps the Boost Bypass Valve open letting that little bit of air bypass the supercharger completely.
    When you mash the gas, more air is coming through the Throttle Body than the engine can pull in on its own and the blower will now be able to build boost in the LIM with that extra air. When there is positive PSI in the LIM (Boost) the Boost Bypass Valve closes and 100% of the air going through the TB is getting into the SC.
    Does that help? I think I explained that alright.
  1. need some help with pulley size
    By mack1212 in forum General Tech Discussion
    Last Post: 04-01-2009, 08:11 AM
  2. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  3. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  4. max boost with 2.9 pulley?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 10:32 AM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
