Thread: Pulley size vs. SC vs. boost
Results 1 to 16 of 16
  1. #1 Re: Pulley size vs. SC vs. boost
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Ok, the second question is pretty much covered, for your first question, no, there's no chart or anything to tell you what boost level you should be at. These are positive displacement blowers, so for every revolution, they move a specific amount of air, in this case 90 cubic inches (hence M90). Your boost levels will depend on how efficiently your engine can use that air. Things like headers, high ratio rockers, etc help your engine breath better, so they would actually reduce your boost (and increase performance).
    2001 Buick Regal LS - Almost Stock
  2. #2 Re: Pulley size vs. SC vs. boost
    chicago
    can you post another pic of the blower cause that does not look like a gen v.
  3. #3 Re: Pulley size vs. SC vs. boost
    SE Level Member porshuh's Avatar
    Jan 2009
    Northern, VA
    Quote Originally Posted by silverbullet View Post
    I only say GenV because in my intro thread a couple different people pointed out that it is a GenV...
  1. need some help with pulley size
    By mack1212 in forum General Tech Discussion
    Last Post: 04-01-2009, 08:11 AM
  2. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  3. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  4. max boost with 2.9 pulley?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 10:32 AM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
