You don't mention if this is with the throttle blocked open, all plugs out and whether you added a little oil for the wet check as well.
There are sometimes many factors that can affect a compression test. Overall your results look good though. Maybe retest those lower cylinders and see if you get a slightly different number.
Some good points Bill.
