Well, with some blocks and the stock jack that came with the car, I managed to get the one side up almost 17.5 inches off of the ground, compared to about 12 inches with my floor jack (keeping in mind again that the car already sits what 7 inches off of the ground) so I pretty much doubled my increased height. I had a jack on the front and one on the back of the passenger side, and then put the jack stands under.
While I did this, I turned on the air compressor and got the air impact wrench out, and then started heating up one of the bolts with the torch. Remember, these things have had a LOT of PB Blaster on them. I sat there with the torch on it for over 15 minutes before I tried the impact wrench... And still nothing moved. I put the heat back on for another 10 minutes and again tried right away, and nothing. I then put it on for another 5 minutes and get out my long handled wrench. I removed the heat and pounded as best as I could, considering I still didn't have a great angle to work at it, with a 5 pound hammer. Still nothing. I used just continual force from me pushing as hard as I could on the wrench (and I am far from a scrawny weakling) and nothing moved...
Not sure if it is worth messing with any more. I've had the car jacked up so many times and no progress is made. I think that I am calling a shop tomorrow and seeing if I can drop it off and be done with it. Ugh! I was hoping to do it myself. Oh well. I'll just be glad when it is done!
