Quote Originally Posted by Standby View Post
first post here want to say hi everyone first.
i have a 98 grand prix gtp, had it for about 5 months now trying to learn more each day. now i have a problem with the car not making full boost. on the stock digital boost gauge it only goes up to half way. it always went up full boost before, i have heard that if there is a leak in teh vacuum system the stock computer will limit the psi and the guage only goes half way. i just got done talking to a gm mechanic and he had no i dea what was going on said it was fine. but its not, i have a leak in the top 1/4 of my gas tank i have yet to get fixed would this mess up the vacuum system and cause this? or is there something else you know of? plz help me been trying to figure this out for alittle while now. also would a pre tuned computer from zzp fix this? also is there any way that the heat now has something to do with this?
Sounds like a vacuum leak. Leaking fuel tank should be fixed as its too expensive to have it spill out but would not affect boost. ZZP pcm wont fix your problem. Lots of good info and threads on how to check for vacuum leaks. Read lots.
