Thread: IC coolant gauge
Results 1 to 20 of 26
  1. #1 IC coolant gauge
    wanna instal a temp gauge for my IC coolant...anyone done this or know the best route to go with in putting one in?
    Jarred
  2. #2 Re: IC coolant gauge
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Good thinking...subscribing to hear the ideas!
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: IC coolant gauge
    May 2008
    staten island,NY
  4. #4 Re: IC coolant gauge
    thanks quickgt! where would be a good place to put it in though?
  5. #5 Re: IC coolant gauge
    May 2008
    staten island,NY
    well it depends what fluid you want to read, before or after the heat exchanger?
  6. #6 Re: IC coolant gauge
    Jan 1970
    Maquoketa, Iowa
    If your only doing 1, you should put it before the core, whatever place is convenient to mount between the pump and core. Some people do both (before and after) just to check how well it is functioning.
  7. #7 Re: IC coolant gauge
    Oxon Hill, MD
    If I was doing it, I'd want to read both inlet and outlet temp. It'd be nice if they had a gauge that displayed 2 temp inputs at the same time. I guess you could do it with an aeroforce if you wanted to.
  8. #8 Re: IC coolant gauge
    Quote Originally Posted by whitelightnin04MC View Post
    I was about to suggest that...hell I bet the aeroforce could tell you which way to turn like a GPS if you wired it right LOL jk
  9. #9 Re: IC coolant gauge
    Waynesboro, PA
    Anyone have any idea what the temperature coming out of the core would be? Going in it should be at least close to ambient.
  10. #10 Re: IC coolant gauge
    Oxon Hill, MD
    Quote Originally Posted by JoshMcMadMac View Post
    That all depends on the core you use. The number of passes the core has, the size of the tubing in the coil, and the GPM of the system all play a factor in how much heat the cooler can reject.
  11. #11 Re: IC coolant gauge
    Waynesboro, PA
    Yes, however I am looking for input from anyone that actually knows what their "stage 2" or standard two inch intercooler has for an output temperature.
  12. #12 Re: IC coolant gauge
    true...guess it helps to know what temp it should be in order to monitor it...
  13. #13 Re: IC coolant gauge
    Lockport, NY
    This thread has some good info: ClubGP Message Forum troubleshooting
    The water temp runs right around 70F, so you more or less need a digital gauge to get an accurate read out. I have been thinking about doing something like that for my S2IC come next spring, if not then i'll likely go with a PLX gauge and sending unit that will read down to 32F. The only other gauge that I have found was a prosport that reads down to 50F.
    w00t first post
  14. #14 Re: IC coolant gauge
  15. #15 Re: IC coolant gauge
    Waynesboro, PA
    Thanks for re-posting the link from the post above.
  16. #16 Re: IC coolant gauge
    Too bad it is the write-up and not the same thread...Just trying to help people out a little bit more dude...don't know why it annoys you, but wasn't it you that said something like this awhile back to me...
    Seriously, waste bandwidth post-whoring like a jack-ass elsewhere.
    Obviously there are some people here that would post how do you do it or where can I find where to get the stuff or something along those lines...just cutting that out and putting the DIY thread link here too. I'll take it down if it makes you feel better.
  17. #17 Re: IC coolant gauge
    Waynesboro, PA
    Yep that was me...because your incessant, pointless post-whoring seems to follow me around this damn forum. Really...post count does not matter. I promise.
  18. #18 Re: IC coolant gauge
    SE Level Member BlackGS's Avatar
    Central Jersey
    Quote Originally Posted by gtpsleeper View Post
    Jarred
    I have a PLX Fluid Temp Sensor hooked up through their DM-100 multi-function gauge. The sensor has hookups for two sensors, but right now I just have one installed, right before the core.
    Pic of the gauge right after the install showing only IC water temp and AFR. I now have it showing boost and oil pressure also:
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  19. #19 Re: IC coolant gauge
    Waynesboro, PA
    Quote Originally Posted by BlackGS View Post
    That sounds pretty trick...I will have to remember to check out the picture when I can actually see it at home.
  20. #20 Re: IC coolant gauge
    are those gauges pretty cheap compared to like an aeroforce?
  1. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  2. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  3. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
