Quote Originally Posted by BlackGS View Post
I have a PLX Fluid Temp Sensor hooked up through their DM-100 multi-function gauge. The sensor has hookups for two sensors, but right now I just have one installed, right before the core.
Pic of the gauge right after the install showing only IC water temp and AFR. I now have it showing boost and oil pressure also:
That sounds pretty trick...I will have to remember to check out the picture when I can actually see it at home.
