Thread: IC coolant gauge
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: IC coolant gauge
    Moore, Oklahoma
    Neat gauge, I could use something like that. What size is it? Where do you get em at?
    Shawn W. Larsen
  2. #22 Re: IC coolant gauge
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by JoshMcMadMac View Post
    Anyone have any idea what the temperature coming out of the core would be? Going in it should be at least close to ambient.
    Anyone?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #23 Re: IC coolant gauge
    SE Level Member BlackGS's Avatar
    Central Jersey
    Quote Originally Posted by Iron Indian View Post
    My gauge is a PLX DM-100 that requires controllers to send info for all the sensors. It is not an OBDII scan gauge, and it is not that cheap. PLX also makes a similar gauge that reads OBDII.
    Here is some info, check out the video:
    PLX Devices Inc. - Multi Gauges, Single Gauges, Sensor Modules, Wideband Air Fuel Ratio, Data Logging, Fuel Saving / Scan Tools
    I buy most of my PLX stuff from needfultoyz.com. They usually have the best price.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  4. #24 Re: IC coolant gauge
    Central Jersey
    Anyone?
    My temps going into the core are always about even with or 1-2* higher than the outside air temp during almost all normal driving. When I am at the track, the temps rise 10+ over ambient unless I'm using ice. I don't know the temps exiting the core, but I hope to have a sensor hooked up for that pretty soon.
    I am using a zzp stage 2 IC with a Frozen Boost type 101 FMHE, gm pump, and a 2.5 quart reservoir.
  5. #25 Re: IC coolant gauge
    Oxon Hill, MD
    Quote Originally Posted by Nightryder View Post
    The water temp runs right around 70F.
  6. #26 Re: IC coolant gauge
    Waynesboro, PA
    Quote Originally Posted by whitelightnin04MC View Post
    Again, that is inlet. Again, I am looking for outlet temperatures.
  1. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  2. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  3. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
