Thread: Coolant Elbow Problem
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: Coolant Elbow Problem
    PA
    Quote Originally Posted by IndeedSS View Post
    Seem to have a higher break rate at the elbow versus the ones not made in China. I found this out when doing a bunch of research for the friend at work needing his replaced. Me, I figured, no problem, it's got to be just like a GP. While similar it wasn't the same. Plus his belt needed replacing at the same time. The stinking motor mount goes through the belt. Thus began web searching. Didn't want to got to his house and look more stupid than absolutely necessary.
    Higher break rate... I could maybe see that because of different materials used to manufacture the elbow. But dimensionally are they different?
    2001 GSE
  2. #42 Re: Coolant Elbow Problem
    GTP Level Member David99GTP's Avatar
    Florida
    I can agree with Dubob, But due to the location, I wanted to be safe than sorry. I have crappy luck. If it can fail it will. LOL
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  3. #43 Re: Coolant Elbow Problem
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by Zef_66 View Post
    The part (elbow) was the same part number as my Impala and the GP's. It was the disassembly that was a little different.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #44 Re: Coolant Elbow Problem
    Where did you get the coolant elbows. Just replaced a bad crank in my GTP and the elbows had been epoxyed in and broke during the tear down.
  5. #45 Re: Coolant Elbow Problem
    Wichita, KS
    Dealerships always stock them. common part to break during removal.
    Local parts stores, O'Reillys for example would have them in their "HELP" section. Same as stock as far as I can tell, but of cheaper quality than OEM for what its worth.
    I always will try to go with OEM for stuff like this I know fails all the time to avoid problems later down the road.
    ~F~
  6. #46 Re: Coolant Elbow Problem
    Barksdale AFB, LA
    When I replaced my LIM gaskets, I used the ones from ZZP. I didn't break my original ones, but I figured as long as I was doing it I might as well put new ones in.
    If you unbolt the tensioner and pull straight to the passenger side of the car, they should come out without breaking.
    2009 Subaru Impreza WRX STI
  7. #47 Re: Coolant Elbow Problem
    Saraland Alabama
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    I thought the help section ones didn't fit as well?
  8. #48 Re: Coolant Elbow Problem
    Wichita, KS
    I have used them in a pinch, and have not had a problem. But when I can...I will always run OEM because of the quality.
    ~F~
  1. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  2. Tefba coolant filters GROUP BUY !!
    By bayareagtp in forum Group Buys
    Last Post: 04-07-2008, 10:43 AM
  3. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
  4. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
  5. still got a problem
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-24-2008, 04:36 PM
