Thread: weird noise
Results 1 to 9 of 9
  1. #1 weird noise
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    ok so this has been happening on and off since i bought the car and i havent been able to find out what it is . ok so here is the story of what is going on .... when i drive the car for a while (15-30min.) when i hit a sharp bump in the road i hear a very loud (almost metalic/almost like the tire coming up and hitting the fender) noise . i think the sound is coming from the rear but sometimes sounds like the front . i am thinking something to do with suspension (i think they are the original struts) or possibly the exhaust hangers are getting hot and letting the exhaust hit something underneath the car . i lifted the car and looked under it and i didnt see anything that look like something hit , also when it was up i tried to shake the spring and strut didnt move at all .
    when i had the exhaust work done to the car (u-bend delete & 3"down pipe) it stopped making the noise then when it went in to get the fuel line fixed it started making the noise again . thanks fellas .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: weird noise
    Milpitas , Ca.
    does anyone have any other idea for me to look at ? i have 2 different options i could just get a full exhaust and hope that makes it stop or i could get my suspension . which sounds more likely to fix my problem ?
  3. #3 Re: weird noise
    PA
    Sounds like it is something in the suspension. But it is so, so very hard to pinpoint a noise over the internet. and even harder when you have no idea if it is even coming from the front or back. It could be a whole host of things, I wouldn't even know where to start. I think that is why you didn't get any responses. No one can even know where to start.
    But my initial guess is it is something suspension.
    2001 GSE
  4. #4 Re: weird noise
    Milpitas , Ca.
    that is what i am thinking too but when i push on my exhaust tips left and right i can make a knocking sound with my exhaust so it has me freaking confused . i was thinking maybe my downpipe is hitting the firewall but it doesnt come from my firewall it is coming mostly towards the rear somewhere .
  5. #5 Re: weird noise
    Milpitas , Ca.
    nevermind i think i know what my problem is .
    How do I know if my strut mounts are bad? - A worn strut mount can be identified in one of two ways:
    * knocking sound from suspension when going over bumps
    * Offcentered retainer on top of mount
  6. #6 Re: weird noise
    TDCRacing
    Guest
    When you mention exhaust...I recently had a problem where my exhaust was hitting something twards the back of the car...shoot i cant remember what it was but i know it led from me having a worn and flimsy rear exhaust hanger and when ever my exhaust would move it would make that noise
  1. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  2. weird clunk
    By MikeGTP88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 04:13 PM
  3. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  4. GTP Tranny Noise, Need Help
    By GTPGP98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-28-2008, 05:08 PM
  5. Whats this noise? (Video)
    Last Post: 02-27-2008, 02:05 AM
