Thread: Coolant Elbow Problem
Results 21 to 40 of 48
  1. #21 Re: Coolant Elbow Problem
    Bastard Reptile's Avatar
    Kansas City, MO
    Eaton Fuller makes this stuff in a little bottle that's specially made to fit o-rings into spaces to prevent nicking them...it's got the consistency of honey, but it works very very nice.
    It comes in about an 9oz bottle, $20 or so, but a little bit goes a looooooooong way.
  2. #22 Re: Coolant Elbow Problem
    Oklahoma
    Reptile, can you link to the product and/or PM me with details.
  3. #23 Re: Coolant Elbow Problem
    GTP Level Member David99GTP's Avatar
    Florida
    Yeah I'd like to pick some up
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  4. #24 Re: Coolant Elbow Problem
    Kansas City, MO
    It's something that we get through our shop...I'll have to get part numbers...
    But if enough people are interested, I can see if I can get ya the hook up.
  5. #25 Re: Coolant Elbow Problem
    Oklahoma
    Put me down for some.
  6. #26 Re: Coolant Elbow Problem
    Florida
    Me too!
    1999 GTP
  7. #27 Re: Coolant Elbow Problem
    PA
    I don't use spit. I usually use sli-glide.
    2001 GSE
  8. #28 Re: Coolant Elbow Problem
    Kansas City, MO
    OK, here's the deal. I can get the stuff. It comes in an 8oz bottle, cost runs $25 + shipping. If anyone is interested, I can order a case of the stuff if we get enough people.
  9. #29 Re: Coolant Elbow Problem
    Oklahoma
    How many people is enough people?
  10. #30 Re: Coolant Elbow Problem
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    so other than oring lube, what is this really used for?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  11. #31 Re: Coolant Elbow Problem
    Kansas City, MO
    Scotty, I'd say 3-4 people. It's really no problem to order the stuff anyway, we use it quite a bit here.
    Lee, anywhere that you use o-rings. It's really good for the coolant elbows, but anywhere you need to use it that may nick o-rings. A group of guys could buy one bottle, divide it up equally. It's good for a club to have just one, since you don't need very much at all to use.
  12. #32 Re: Coolant Elbow Problem
    Oklahoma
    As long as I have the funds when you place your order, Id take one.
  13. #33 Re: Coolant Elbow Problem
    St Louis MO
    Quote Originally Posted by Reptile View Post
    Ah I understand...it is really good o-ring lube. It must be REALLY slick stuff. Don't let Scotty buy too much or it will wind up in his supercharger.
    2010 Camaro SS LS3
  14. #34 Re: Coolant Elbow Problem
    GT Level Member DuBob's Avatar
    Lititz, PA
    I use some silicone grease on the o-rings (injectors, coolant elbows, etc).....no problems here.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
  15. #35 Re: Coolant Elbow Problem
    Kansas City, MO
    Exactly....makes the fuel rail go right in, also keeps the o-rings softer for a little longer.
  16. #36 Re: Coolant Elbow Problem
    Florida
    I had no lube so I used a tiny bit of plug boot grease. I ended up going to Pontiac and buying the GM elbows. Decided the extra $ is worth saving the hassle. They came to 16 bucks for the 2 elbows. I bit expensive but after reading all the hassle with the Help section elbows I decided not to chance.
    1999 GTP
  17. #37 Re: Coolant Elbow Problem
    Lititz, PA
    I've never had any issues with the Help section elbows and @ $4, they can't be beat. They look exactly the same as OEM to me......down to the color of the o-rings.
  18. #38 Re: Coolant Elbow Problem
    St Louis MO
    Quote Originally Posted by DuBob View Post
    There are differneces in the Help section ones, and thus the problem. Not sure if it's visual, but the chinese ones won't last...according to the Bonne guys.
    2010 Camaro SS LS3
  19. #39 Re: Coolant Elbow Problem
    PA
    Quote Originally Posted by IndeedSS View Post
    Now I am curious...whats the difference?
    2001 GSE
  20. #40 Re: Coolant Elbow Problem
    St Louis MO
    Quote Originally Posted by Zef_66 View Post
    Seem to have a higher break rate at the elbow versus the ones not made in China. I found this out when doing a bunch of research for the friend at work needing his replaced. Me, I figured, no problem, it's got to be just like a GP. While similar it wasn't the same. Plus his belt needed replacing at the same time. The stinking motor mount goes through the belt. Thus began web searching. Didn't want to got to his house and look more stupid than absolutely necessary.
    2010 Camaro SS LS3
  1. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  2. Tefba coolant filters GROUP BUY !!
    By bayareagtp in forum Group Buys
    Last Post: 04-07-2008, 10:43 AM
  3. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
  4. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
  5. still got a problem
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-24-2008, 04:36 PM
