Neat gauge, I could use something like that. What size is it? Where do you get em at?
My gauge is a PLX DM-100 that requires controllers to send info for all the sensors. It is not an OBDII scan gauge, and it is not that cheap. PLX also makes a similar gauge that reads OBDII.
Here is some info, check out the video:
PLX Devices Inc. - Multi Gauges, Single Gauges, Sensor Modules, Wideband Air Fuel Ratio, Data Logging, Fuel Saving / Scan Tools
I buy most of my PLX stuff from needfultoyz.com. They usually have the best price.
My temps going into the core are always about even with or 1-2* higher than the outside air temp during almost all normal driving. When I am at the track, the temps rise 10+ over ambient unless I'm using ice. I don't know the temps exiting the core, but I hope to have a sensor hooked up for that pretty soon.
I am using a zzp stage 2 IC with a Frozen Boost type 101 FMHE, gm pump, and a 2.5 quart reservoir.
