The problem is you need to know the engine's forward (not back firewall) cylinder head (bank 0 I think) temperature! These cars (like most) have no "head" temperature sender, only the one that measures the temperature of the circulating coolant liquid.
At low RPM not enough coolant is circulating quickly enough to prevent heat spikes in the heads nor to measure the true head temperature, especially the front bank head which has no air cooling headroom up to the hood, (header heat is trapped there by the plastic engine cover thingy) due to the low hood-line.
Just like in water and air, in an engine (cast iron, steel or aluminum) HEAT ALWAYS RISES!
If you heat a bar of steel with a torch it melts more quickly with the torch flame applied at the top than it will if you try to heat (melt) the bottom! You have to get the whole thing red hot (saturated sink) to start melting the bottom.
So what is happening here is "heat riser sinking" up into the cylinder heads (valve covers, blower) and the ICM mounting platform! We need to add some added auxiliary air cooling for this riser heat that may not show up in the coolant temperatures until AFTER the (water pumped) RPM rises! Also when the coolant is not circulating with ignition off the ECM has no clue how hot the engine (particularly the forward cylinder head) gets afterwards AFTER the car is parked. (we are talking 45 minutes of serious 200˚+ oil-after-baking, even with fans)
All you need is a piece of wire connected to the upper right terminal (2000 GTP) of Relay 12 to activate both fans on Low. Simply ground the wire (turns on Relay 12) through a switch or thermostat on the head or ICM platform! (will not interfere with ECM should it ever need to activate Both/High Mode either)
Even for regular daily use in heavy summer city traffic I would recommend adding an ignition powered relay to turn the fans on Low (Ground Relay 12 return) FULL TIME (if you don't have or can't find a suitable button thermostat to only do so automatically) while the engine is running, especially if you use lower grades of gas and wish to keep the decorative top plastic cover thingy fitted, blocking upper over the engine airflow convection from the front cylinder bank/headers. These 185˚ button thermostat switches can be grabbed at any HVAC dealer, look up Hunter (cottage/RV) wall furnace "Blower Kit". Those cooling (close on high temp) button thermostat switches are around $15 so a $3 relay might be cheaper but wont help you (or your oil) when the car is parked. We need a furnace "forced-air heat exchanger blower motor" type thermostat switch that only turns "on" when the temp rises above it's value/setting.
Since the ECM only has two transistor outputs dedicated to running the fan relays, one does what I mentioned above (grounds Relay 12) and the other turns on (grounds) both Relay 9 and Relay 10 (hard wired together, so grounding either does both) for high speed mode. Note the polarity use of pins 85 and 86 on GM/Siemens relays is reversed on some relays! Use a meter to find out which side has 12v before adding-in a wire to ground the other coil "return" terminal pin! (to test or activate it)
The big Siemens relay's coil pins are at the lower left and the upper right socket holes. (which is the coil power and which is coil return varies - see above)
To run the fans on high with a switch all you need are 2 IN4005 'blocking" diodes connected to the one wire (again) connected so that the wire can ground 2 (all 3) relays at once as the ECM does (with 2 outputs). The two "blocking" diodes prevent the ECM from ever having to risk running ALL 3 relays with only one of it's output transistors. (Probably not any big deal, but worth noting and paying attention to, do not "jumper" Relay 12's coil return to either Relay 9 nor Relay 10's coil return(s) - use 10 cent diodes!)
This way, (with diodes) even though you have all 3 relays effectively "jumped" for your "fans on high" grounding wire/switch, the ECM can still turn on Relay 12 alone (Low speed) whenever your thermostat switch is not also "calling for" High speed mode (if you wish) cooling! No diodes are necessary to run Relay 12 (both fans Low) alone.
The fans can run in 3 possible modes: (ECM uses 2 fans/both together only!)
Relay 12 ON - both fans on Low (series connected 6v Mode)
Relays 9+10 ON - ONLY driver's side fan runs on High (!2v Mode) (#error - very bad, see below#)
All 3 Relays ON - Relay 12 runs passenger side fan on High (12v Mode)
The middle "driver's fan only" on High mode (R9+R10) above is bad/useless! It just blows (and traps) BOTH THE CYLINDER HEADS HEAT over to the ICM/Belt Battery passenger side and slightly cools the transmission and one cylinder a bit. If you're stuck in bumper to bumper traffic, one fan alone is useless, it just blows heat around like a convection oven, trapped across the rad/grille clearances.
Doubtless even if this was reversed so the passenger/ICM side fan was the single (R9+10) default fan, we'd be "convection baking" the ATC/ABS, tranny and cruise control, it was not a good idea either! You always need both fans on Low or High ONLY, creating positive air pressure sucking/blowing in cold air evenly and forcing the coolest hot air out the bottom of the engine compartment.
Running both fans on High is noisy and definitely not easy on your battery for post-cooling after you've parked the car!
