Thread: Update on my fuel rails
Results 1 to 20 of 45
  1. #1 Update on my fuel rails
    GTP Level Member David99GTP's Avatar
    Florida
    Well, Paul from PRJ said the gen 3 rails turned out fantastic and they should arrive by end of next week.
    Sooooo I decided to get a head start and pull off my stock rails. Wasnt too bad except the injectors pulling out with the rails. Of course it was the back drivers side which is a PITA to get to LOL.
    My question is I thought someone on here said save myself issues and replace O rings? There are O rings top and bottom on the injectors. Should I replace all of them. Also one pulled off and the small retainer that seems to hold the O ring on the bottom portion fell off into the engine bay abyss and I cant find it. Will a place like NAPA have these or do I need to go to a dealer?
    Any other tips before I get my rails as far as install I'd appreciate your input.
    Thanks In advance
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  2. #2 Re: Update on my fuel rails
    Florida
    1999 GTP
  3. #3 Re: Update on my fuel rails
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by David99GTP View Post
    Thanks In advance
    PM Farnsworth, he has a complete ring kit, upper, lower for each injector and two per each fuel line. Pretty cheap too. I can't comment about the broken injector with authority so I will leave it to someone more qualified.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Update on my fuel rails
    Florida
    I checked onine and saw ZZP and Intense has new injectors. ZZP offers a 10 dollar rebate for each one returned. They have 25lb, 42.5 lb. What is on a stock GTP?
    I'll check with Farnsworth on the kits
    1999 GTP
  5. #5 Re: Update on my fuel rails
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    dont worry about that tab, just make sure the orind is properly seated.
    you can also get o-rings form zzp
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  6. #6 Re: Update on my fuel rails
    Florida
    Quote Originally Posted by scooz14 View Post
    Yeah I just saw the o-rings on ZZP. I didnt know if that plastic ring /clip was necessary or important. ZZP offers a 10 dollar rebate for returned injectors when you buy them but it states they must have the ring/clip. So I thought maybe its bad if I dont have it on when I reinstall the injectors.
    1999 GTP
  7. #7 Re: Update on my fuel rails
    Oklahoma
    Im not sure about the broken clip. Its used to hole the o-ring, so I would consider it important. Its part of the structure of the fuel injector so I personally would be hesitant to put it back in.
  8. #8 Re: Update on my fuel rails
    Florida
    That was my concern, figured its there for a reason and why would ZZP not give a credit on a core return without it if it wasnt important.
    1999 GTP
  9. #9 Re: Update on my fuel rails
    GT Level Member DuBob's Avatar
    Lititz, PA
    They commonly break. You'll probably break more of them as you remove and replace the o-rings.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
  10. #10 Re: Update on my fuel rails
    Oklahoma
    Quote Originally Posted by DuBob View Post
    And they will be okay like that?
  11. #11 Re: Update on my fuel rails
    Wichita, KS
    The injectors are clipped onto the fuel rail, so when you remove the rail, the injectors are made to come with it. Its a nice thing they did by adding the injector clips. Thats normal.
    The part you broke off happens with age, and heat being on them all the time. Its normal, but you want to avoid it if you can. Sometimes you cant though.
    The part that broke off only holds the o-ring onto the injector when you pull it out of its bore. With it missing, it wont hurt anything with it missing, just when you pull out the injector, the o-ring may stay behind. Not big deal, you can dig it out with a small screw driver.
    The part that fell down into the injector hole...if you can, get you a thin piece of metal and add some tape to the end of it, sticky side out, and see if you can retrieve it. If you cant, it wont hurt anything as small as it is. I will adventually work its way down the exhaust pipe and get stuck to the cat and melt away over time.
    When I did the o-ring replacement on the GF's car, this happed to me as well, and couldn't get the piece that broke off out of the engine, and haven't had any problems to date. That might make you feel better.
    As for the o-rings, its recommended that EVERY TIME you remove the injector, you replace the o-ring. Thats a bit much, but if you have never replaced them, then yes, by all means you should now. They are cheap, and worth the investment to protect your investment as I always say.
    You can get the injector o-rings from any auto parts store. I know O'Reillys sells them 2 per box, so you will need 6 box's of them.
    I can get them as well, in bulk sometimes cheaper. I provide a full set to do a L67 and the feed and return fuel line quick connects as a complete set for $14.00 shipped to your door. Thats 12 injector o-rings, and 2 feed line quick connect o-rings, and 2 return line quick connect o-rings.
    ~F~
  12. #12 Re: Update on my fuel rails
    Wichita, KS
    Oh, for got you say, that when your changing the o-rings out, instead of rolling them off the injector, its better to cut them off. I use a thin pair of cutters I have, but you could carefully use a razor blade as well.
    When they get old, they get hard, and if they don't crack or break off when you try to remove them, then they will break off the little plastic lip of the injector you broke off in those pictures. I try to avoid this when I switch them out for people, so thats why I cut them off every time. Its a much better method.
    ~F~
  13. #13 Re: Update on my fuel rails
    Florida
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    WOW, Thanks so much. I can sleep now over the lost piece. I have been thinking of a whole new route. What about upgrading to say 42.5lb injectors? ZZP offers a set flowmatched. Is this over kill for my current setup? My PCM was purchased from PFYC and was programmed by digital horsepower. Will I need my PCM programmed /tune again with new injectors?
    Maybe I am answering my own questions here LOL, guess with all I am doing maybe a tune would be good anyway. I never did do a case learn. Guess I am on the fence if upgraded injectors are a good idea. I was gonna go with OEM but NAPA was about 114 a piece!! Since mine have 110K wasnt sure my best route here.
    1999 GTP
  14. #14 Re: Update on my fuel rails
    Williston, North Dakota
    Yeah I haven't had any problems with broken plastic tabs on the bottom.
  15. #15 Re: Update on my fuel rails
    SE Level Member Incomudrox's Avatar
    New Holland, PA
    Wow...I have never broken any yet....sucks.
  16. #16 Re: Update on my fuel rails
    Florida
    I went to the site and the prices were reasonable. I am going to send them mine Monday. After 110K it has to be a good idea. Plus while I have everything off its a good time to do it.
    1999 GTP
  17. #17 Re: Update on my fuel rails
    St Louis MO
    are you using deatschwerks? iirc this is the company WBS gets there injectors from.
    2010 Camaro SS LS3
  18. #18 Re: Update on my fuel rails
    Florida
    Quote Originally Posted by IndeedSS View Post
    Yes I plan on using deatschwerks.
    1999 GTP
  19. #19 Re: Update on my fuel rails
    Banned
    New Port Richey Florida
    David you need to replace that one thats broken. Because over time the injector could wiggle around and come un seated that clip that broke off also helps hold the injector in its seat to keep a tight seal in the rail
  20. #20 Re: Update on my fuel rails
    Hoffman/Schaumburg, IL
    Could you just run two -rings? cause that part looks like roughly the same size as the o-ring..... Just an Idea
  1. My turbo update
    By UR LOSN in forum Members Rides
    Last Post: 04-09-2015, 07:09 AM
  2. Polishing stock fuel rails [*]
    By chitownchevy in forum How To Write-Ups/Tech Tips
    Last Post: 06-22-2009, 01:52 PM
  3. PRJ Gen 3 fuel rails?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2008, 02:42 PM
  4. Who's Done Homemade Fuel Rails (With an fittings)
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 04:13 PM
