Thread: Update on my fuel rails
Results 21 to 40 of 45
  1. #21 Re: Update on my fuel rails
    GTP Level Member David99GTP's Avatar
    Florida
    I went to the site and the prices were reasonable. I am going to send them mine Monday. After 110K it has to be a good idea. Plus while I have everything off its a good time to do it.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  2. #22 Re: Update on my fuel rails
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by David99GTP View Post
    are you using deatschwerks? iirc this is the company WBS gets there injectors from.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #23 Re: Update on my fuel rails
    Banned
    New Port Richey Florida
    David you need to replace that one thats broken. Because over time the injector could wiggle around and come un seated that clip that broke off also helps hold the injector in its seat to keep a tight seal in the rail
  4. #24 Re: Update on my fuel rails
    Hoffman/Schaumburg, IL
    Could you just run two -rings? cause that part looks like roughly the same size as the o-ring..... Just an Idea
  5. #25 Re: Update on my fuel rails
    St Louis MO
    Quote Originally Posted by 19SE92 View Post
    With the rails in place I don't see how there would be any movement.
    2010 Camaro SS LS3
  6. #26 Re: Update on my fuel rails
    Oklahoma
    I dont see either how it would come unseated. The fit is pretty tight to begin with, plus you have the rail itself physically holding the injector in place. My concern would be leaking primarily.
  7. #27 Re: Update on my fuel rails
    Florida
    Quote Originally Posted by IndeedSS View Post
    Yes I plan on using deatschwerks.
    1999 GTP
  8. #28 Re: Update on my fuel rails
    Florida
    Thats what I wondered. If the rail holds the injector in place how does that clip do anything but hold the O-ring on? For such an important part why does everyone only stocks O-Rings for replacement. Why not have the O-Ring and clip available for replacement? Obviously it must be a common problem. With time and heat these things must get brittle.
    1999 GTP
  9. #29 Re: Update on my fuel rails
    Oklahoma
    They do become brittle. I think you would be fine because the O-Ring would be the part would be there and Im sure with the rails holding everything down there probably would not be an issue. However, its not something I would feel particularly comfortable trying out.
  10. #30 Re: Update on my fuel rails
    Florida
    I know, all I can pictue is fuel spraying on my new valve covers or worse yet I get it all put back together looking sweet and then FIRE!!!
    1999 GTP
  11. #31 Re: Update on my fuel rails
    Oklahoma
    I would be a purty fire though, just be sure you keep a camera with you so you can get pictures, LOL
  12. #32 Re: Update on my fuel rails
    St Louis MO
    The "clip" is a molded piece so it's not replaceable. Many many people run these w/o the lower oring retainer w/o issue. I think new properly installed orings is the key here. I believe the injector to rail retainer is the clip.
    Disclaimer: I've been wrong in the past, so one should really verify anything I say.
    2010 Camaro SS LS3
  13. #33 Re: Update on my fuel rails
    Oklahoma
  14. #34 Re: Update on my fuel rails
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    It would be helpful here, if you merely suggest that this could be an issue. stating this as fact is irresponsible. We understand your concern. However, if you look at all of the different type of injectors available for these motors, pretty much NONE of them have the same style or size body/clip/ANYTHING past the O-Ring. some are similar to the OE clip part that broke. most look noting like it, smaller even. so that missing part is not going to affect how the injector holds in it's bore-- if it did, every other injector would be made exactly the same way. -- the fuel rail holds the injector in place, the O-ring seals it.
  15. #35 Re: Update on my fuel rails
    Florida
    I appreciate everyone's input. Thats what I love about this board everyone helping out. This forum has saved me time and money!
    1999 GTP
  16. #36 Re: Update on my fuel rails
    Wichita, KS
    This is correct.
    Replacing your stock injectors is not needed till your maxing yours out. You will know this by scanning and watching the IPW etc. during WOT runs.
    ~F~
  17. #37 Re: Update on my fuel rails
    St Louis MO
    Thanks for the backup Jason.
    2010 Camaro SS LS3
  18. #38 Re: Update on my fuel rails
    Wichita, KS
    Your welcome.
    x100
    Also cracks me up when people say they found their fuel leak...they forgot to install their injector clip. Time and time again I tell people these clips have nothing to do with the injector sealing or not, they are there to hold the injector to the rail, so when the rail is removed, all injectors come out at the same time, vs. pulling the rail, then each injector one by one.
    If your injector is leaking, then the fuel rail is not correctly installed onto the LIM, or you have an injector missing its hole all together. Its not rocket science how these parts go together. LOL
    ~F~
  19. #39 Re: Update on my fuel rails
    Florida
    Thanks! You guys are so much help. I was losing sleep until I started asking questions on this board. I think I'll get through my spring build aok.
    1999 GTP
  20. #40 Re: Update on my fuel rails
    Florida
    Well, just as I was about to send my injectors off for cleaning and flow matching I found a deal on a set of 38lb Lucas Steel Jacket Injectors. Has anyone had experience with these? I bought them slightly used for a little more than I wouldve paid to have my stockers refreshed and tested. Plus I figured this would leave the door open if I heavily mod the car in the future.
    I was told I can run a stock program file on my PCM and that it will just run rich. I have an upgraded PCM, but I still plan on a tune. I just want to be able to drive the car until a tune.
    1999 GTP
  1. My turbo update
    By UR LOSN in forum Members Rides
    Last Post: 04-09-2015, 07:09 AM
  2. Polishing stock fuel rails [*]
    By chitownchevy in forum How To Write-Ups/Tech Tips
    Last Post: 06-22-2009, 01:52 PM
  3. PRJ Gen 3 fuel rails?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2008, 02:42 PM
  4. Who's Done Homemade Fuel Rails (With an fittings)
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 04:13 PM
