ok so i just had a p0300 come up random misfires and no other codes
i looked at misfire history this is what it shows
cyl 1) 0
cyl 2) 0
cyl 3) 81
cyl 4) 655
cyl 5) 4
cyl 6) 2
So i do know i had some from cyl 2 4 6 cus i forgot to plug in my injectors when i painted my fuel rails but i cleared those when i tuned the car with hp tuners.And it apparently worked cus there are none on 2 so the ones on 4 and 6 must be recent.
I am running rich though. My o2 b1s1 was reading up to 1045 at wot. So could i of started to foul my plugs i recently changed about 2k ago?
My ltft were all within -4.
I have 0 kr.
I did notice awhile ago when i took off my ecm that it was pretty beat up so im thinking that could also be an issue.
I did my lim and plenum and coolant elbows about 1k ago and torqued them to specs but i didnt put anything on them so is it possible they loosened?
My vac seems to be good though at 19-22 at idle.
Also i changed out my therm for a 180 and tuned it for it and noticed yesterday my coolant res was low and i could hear the coolant like flow through from inside the car like there was air in it so i threw in some coolant today.
Also another thing to note i took off the protective metal sleeves on the plug boots when i changed the plugs the last time cus i heard they have been known to cause issues and never put on different sleeves.
I did get gas at this random station yesterday and filled from empty so i have no idea the quality of the gas soo who knows.
