Thread: Vacume barb for keeping pcv function
Results 1 to 13 of 13
  1. #1 Vacume barb for keeping pcv function
    Jersey
    I ordered a N* t/b kit from zzp. First thing i noticed was there was only one barb on the t/b itself for the fuel pressure regulator. In the picture on their site it shows a barb in the adapter plate too, to hook up pcv. Its not a big deal It didn't come with it but, How would I go about getting a barb like that and installing it?
    16' wrx sti- stock
  2. #2 Re: Vacume barb for keeping pcv function
    Banned - Busted For Scamming
    Feb 2009
    thats press in, although you could tap it and use a different barb
  3. #3 Re: Vacume barb for keeping pcv function
    Jersey
    where do i get a barb like that?
    16' wrx sti- stock
  4. #4 Re: Vacume barb for keeping pcv function
    Feb 2009
    try the parts store, you could go to home depot, maybe they have something there, they have all sorts of stuff in the plumbing section.
  5. #5 Re: Vacume barb for keeping pcv function
    Jersey
    Im hoping they have them there, im gonna go check tomorrow morning.
    16' wrx sti- stock
  6. #6 Re: Vacume barb for keeping pcv function
    Jersey
    well in case anyone is in the same boat as I am and hates the idea of running a breather, there is a simple way to run 2 lines. I went to lowes and picked up a 1/8th" to 1/4" threaded barb, a 1/4" tap, and a drill bit. I drilled and threaded a hole into my genV adapter plate. Now i can run my fuel pressure regulator and have pcv function.
    16' wrx sti- stock
  7. #7 Re: Vacume barb for keeping pcv function
    Feb 2009
    glad to hear you got it going.
  8. #8 Re: Vacume barb for keeping pcv function
    Jersey
    Thanks man!
    The finished job
    16' wrx sti- stock
  9. #9 Re: Vacume barb for keeping pcv function
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Hold on a minute, does that just go through to the main inlet? If so, it's just another vac source and won't work for the inlet side of the PCV, which needs to come from between the MAF and TB plate.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: Vacume barb for keeping pcv function
    Jersey
    Quote Originally Posted by Scimmia View Post
    no thats for my fuel pressure regulator vacume source, its in the same spot as on my stock throttle body, right after the flipper plate. the pcv is going to the top barb on the N*. Its the same setup as shown here
    16' wrx sti- stock
  11. #11 Re: Vacume barb for keeping pcv function
    QCA, IA
    OK, I gotcha now, I thought you were asking about adding a barb for the PCV.
  12. #12 Re: Vacume barb for keeping pcv function
    Jesus that throttle bracket is all sorts of strange lookin'
  13. #13 Re: Vacume barb for keeping pcv function
    Jersey
    LOL yeah its goofy as hell
    16' wrx sti- stock
  1. Keeping the wheel pressure mon. sys. w/new wheels
    By Sudden in forum Tires & Wheels
    Last Post: 05-31-2009, 11:05 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Broken function
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:14 AM
  4. The Search Function Works!!! OMG!
    By Lawngoose in forum Off Topic Discussion
    Last Post: 12-27-2007, 11:07 PM
