Whats up guys, I know this is my first post on the forums but i have been cruising them since early last year. So i'm having some issue with the GTP and need some superoir insight as i am lost now.
Just a brief run down. I've popped a few codes as of late and they are Maf code (which is new within the month) and insuff. EGR flow (EGR valve as been replaced within the month as well and seafoamed the egr system while i was at it.) And also the O2 bank 1 sensor 2(rear one.) Still getting codes with new parts.
Now this is what the car is doing. when i'm driving down the road and i let off the gas to go into a turn or off ramp. the idle drops and bounces from 400 to 1000 rpms sometimes dying. Now this is a problem when doing 70 mph and you go to exit a highway, surprise, ZERO powersteeringbut when just sitting at an idle without the car moving it idles fine. I have also cleaned the ICV thinking that may help my issues but no. Also my MPG have dropped from around 21-22 to 16-17 during all this
I can live with a bouncing idle but not about smashing gaurdrails with my 2 year old daughter in the car.
i have started the car and while running unplugged the tps, map, and icv and none of them had any affect on how the car ran. Doesn't drop idle, change or studder at all. So i'm thinking i may have a bad driver in my PCM. is this possible???
I'd like to hear from some of the senior members on here or just a GTP guru. i have done alot of trouble shooting and just would like to get to the bottom of this. Thanks in advance for taking the time to read my long post guys.... T.J
