Thread: need help ASAP PLEASE
Results 1 to 19 of 19
  1. #1 Re: need help ASAP PLEASE
    Bad spark plug...was it damaged? If so then you have internal issues...if not then don't worry about it. Not sure if the CPS throws a code...never had any issues with mine. Cat...what cat? I'd get rid of it so you don't have to worry about it. Also...since yours is a '99...you might fuel pump issues...try bending the sensor tab seen here in this pic...
  2. #2 Re: need help ASAP PLEASE
    Cincinnati, Oh
    what exactly does putting the fuel pump in high mode do?? i mean sounds like more fuel output??? and yes i do want to get a down pipe to take the ubend and cat out. but wanted to try to fix this issue before and performance mods you know what i mean.
  1. 8 rib help! asap please!
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2009, 05:40 PM
  2. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  3. I need a l67 asap !!!!!!!!
    By hatrain32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 09:25 AM
  4. IAC relearn ASAP?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-29-2008, 12:23 PM
