Thread: Cold Air Intake mitigated by forced induction?
Results 1 to 10 of 10
  1. #1 Cold Air Intake mitigated by forced induction?
    SE Level Member Chernobyl's Avatar
    Chicago
    Is it worth buying a cold air intake with the supercharger where it is without an intercooler?
    I heard that the benefits of having the cold air intake are mitigated by the heating action of the supercharger, and it is more economic to just put a short ram setup on the car.
    Is this true, not true?
    I can always stick a pipe and a cone filter on there, and upgrade to a CAI box later, and reuse the cone, so it's not a huge issue, I'm just curious.
  2. #2 Re: Cold Air Intake mitigated by forced induction?
    oh my god!! someone finally sees my point!!
    i have a cone right on my throttle body. the blower heats up the air anyway, so who cares. more flow = more power.
  3. #3 Re: Cold Air Intake mitigated by forced induction?
    Barksdale AFB, LA
    Yes, it will heat it up anyway, but the cooler the air starts the cooler it will be when the supercharger's rotors are done with it. When you get an IC just go open cone and let the IC do its job.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Cold Air Intake mitigated by forced induction?
    TDCRacing
    Guest
    The cooler the air is upon entering the S/C the less it will be heated up.
    Let's say at 1000RPM's the blower is heating the air intake charge up 30*F. Well if the air entering is 80*F then you have 110*F
    What if the air entering the intake or supercharger is 50?
    Exactly. Cooler more dense air. AND power.
    Flow means nothing if you don't have the power to make the flow.
  5. #5 Re: Cold Air Intake mitigated by forced induction?
    Aug 2008
    Long Island, New York
    yea i say with a good meth injection setup or IC then go with an open cone, but otherwise a cold air is good
  6. #6 Re: Cold Air Intake mitigated by forced induction?
    Charles City, IA
    I think I might sell my wizair soon and get a meth kit. Then I will run a cone off the TB
    SMGPFC Two Nipple General
  7. #7 Re: Cold Air Intake mitigated by forced induction?
    Chicago
    I ended up ad-hocing an intake with some PVC piping and a 7inch cone filter. It sits about on top of the PCM. Driving it a bit around, I can already notice a difference in acceleration response and such. I also adore the supercharger whine...
    I figure I'll pick up a wizair sometime soon and just reuse the cone with that. This only cost me 25 bucks in piping and connectors, plus the 50 for the filter, so it's not too bad for minimal effort.
  8. #8 Re: Cold Air Intake mitigated by forced induction?
    Quote Originally Posted by Chernobyl View Post
    i would leave it as is. the only difference youll see with a box around the cone is when youre sitting still or driving slow in traffic. anytime youre moving the air should be pretty near ambient anyway.
    this is why open cones are best, because of the fact that there is so much air moving around the engine bay while youre already moving that it doesnt matter about where the cone sits. flow beats out on temperature as far as power goes.
  9. #9 Re: Cold Air Intake mitigated by forced induction?
    Plus the more modded you are the better the open cone setup becomes.
  10. #10 Re: Cold Air Intake mitigated by forced induction?
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I need to make one I have no time I will try this weekend
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. Custom Cold Air Induction [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-04-2009, 05:05 PM
  2. Help-cold Air Intake
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 01-29-2009, 12:36 AM
  3. Cold Air Intake
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 02:25 PM
