Thread: Burning oil, misfire #2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Burning oil, misfire #2
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Well, once again I come back to the PCV system, as that's the only way I could see oil getting there. As you get more blowby at high RPM/high boost, the inlet of the PCV system works in reverse, and oil vapor gets blown into the throttle body. This is normal operation, but if you have that much, there could be something else wrong, although I can't think what it would be.
    I hate to sound like a broken record, but it's the only thing I can think of If you're pulling the SC off, I would blow compressed air through each of the PCV passages and see if you can detect any problems.
    2001 Buick Regal LS - Almost Stock
  2. #22 Re: Burning oil, misfire #2
    VT
    Quote Originally Posted by Scimmia View Post
    The voice in my head sounds like a broken record too, so dont feel bad.
    Im going to try that with the air and see what I can find out. If im still stumped Im going to block the pcv off right at the lim. Ill then leave the oil cap off and see how she does.
    I will make sure to take pics and even a couple videos to help show her current state.
    Edit- I just found a vacuum diagram, Ive searched several times but never found anything.
    Anyhow its safe to say the Map sensor as it is right now has no line even going to it, in fact anything vacuum operated is not right at the moment. I had a feeling it wasnt perfect but if fact nothing is right.
    This is the diagram that I am looking at incase anybody wants to look at it-
    http://fullthrottlev6.com/upload/fil...%20DIAGRAM.jpg
    Now the triple vacuum tree on the top of the s/c shows 2 vacant spots. If I remember correctly there is a large on for the brake booster and the other small one is for the acc?
  3. #23 Re: Burning oil, misfire #2
    VT
    Well I got back today and spent a little time repairing all the vac lines so everything is in order as far as that goes.
    Im going to have to tear down and fully inspect the pcv system, I know this for sure now. I sealed the intake port to the pcv as well as the throttle body and tried to turn it over. When cranking she still pulled vacuum on the crankcase! So I believe either one of the fresh gaskets failed or something is warped/cracked.
    I was also shocked at how little pull the intake had when I put my hand over it. I could actually stall the motor just by placing my hand a couple inchs away.
  1. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  2. Heated seats + Burning Smell?
    By xerxescct in forum General Tech Discussion
    Last Post: 01-25-2009, 11:31 PM
  3. Burning rubber or spinning tires
    By grand prix newb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2008, 07:17 PM
  4. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
  5. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
