I think THAT^^ one is for the L36, not the L67...not sure if they are the same though.
it doesnt use one, its returnless. it has a pressure sensor in the fuel rail and the computer varies the speed of the fuel pump to adjust pressure. for your application you need a 97-03 l67(supercharged) fuel rail, try the junkyard or if i come across one i can get it for you.
Back to the timing chains. I was going to do a stock non-roller replacement until I saw that zzp has the rollermaster single timing chain for a lot less than 3800 performance:
ZZ Performance Singe Roller Chain
Anyone have any input on it? I'm keeping the rest of the motor stock.
btw, I have seen the few threads about problems with the double roller.
