Thread: Terrible stuttering/stalling problems
Results 1 to 15 of 15
  1. #1 Terrible stuttering/stalling problems
    SE Level Member Chernobyl's Avatar
    Chicago
    I have a 2001 Grand Prix GTP. It has about 100,000 miles on it, bought it at 92,000 for about six grand, it was in really good condition, and it ran great, and has ever since I bought it.
    I recently returned from a trip from St. Louis back to Chicago, and I had my oil changed at Jiffy Lube. Car was fine, hardly drove it in the next two days, then I went and got gas at a BP station, premium like always, but in retrospect, I realized they were filling the underground tanks.
    About 2 minutes after leaving the station, she started stuttering, and I'm assuming it was some sort of misfiery thing. The SEL came on, and I managed to get the car home.
    I had thought that maybe I had gotten water in the fuel system, so I let her sit, and started it up, and it promptly stalled out from idle. I started it up again, it ran rough for a while, then ran ok enough for me to run to Autozone to pick up a bottle of Heet, thinking that would fix the water problem. I also had them pull the SEL code, and it was something about the MAF sensor. Lean MAF something or other. So I also picked up a bottle of MAF cleaner and the Torx bits.
    The Heet did little to nothing, so I pulled the MAF and sprayed it down. I promptly replaced it, where the car died on me. I got it running and it was horribly stuttery and jerky. I had assumed that if it was the MAF sensor, cleaning it would fix it... So I pulled the connector, and lo and behold, the car runs rough at idle, but she's fine other than that.
    Sorry for the horribly long post, but should I just bite it and buy another MAF sensor to replace it? And if so, aftermarket, or OEM? Does it matter even?
  2. #2 Re: Terrible stuttering/stalling problems
    TDCRacing
    Guest
    If you have a lean code then typically those are form vacume leaks. I have never had a vacume leak cause a stalling issue on one of these cars, But it is possible.
    Verify that code for us.
  3. #3 Re: Terrible stuttering/stalling problems
    Chicago
    Quote Originally Posted by TDCRacing View Post
    But then why would disconnecting the MAF sensor help? I'll have to go and find out what that code was for sure.
  4. #4 Re: Terrible stuttering/stalling problems
    TDCRacing
    Guest
    I'm not sure. All that happens in the PCM when the MAF is unplugged is the PCM resorts to the VE table. Which is pretty close to the MAF as far as fueling goes.
    If your thinking that the MAF is bad then that's not the case. I have never heard of the MAF going bad and throwing a lean code. Like I said the most common symptom of a lean condition code is a vacume leak on these cars.
    Although I guess anything is possbile.
  5. #5 Re: Terrible stuttering/stalling problems
    Chicago
    How do I go about hunting down a vacuum leak? I know a fair bit about these cars, but everything I know, I've learned in the past month. Am I better off taking it to a mechanic and telling him that's what I believe it is?
  6. #6 Re: Terrible stuttering/stalling problems
    TDCRacing
    Guest
    Look first. Look by the Evap canister (little round black thing near the middle of the firewall. Should have a vacume line running to it. Make sure they are all the way pushed on. Check your spark plug wires also. If you can get the car to run spray the lines down with carb cleaner. IF you hear the idle raise you've found your leak. It's either going to be a hose that's dry rotted or a hose that is not connected properly.
  7. #7 Re: Terrible stuttering/stalling problems
    Chicago
    Code was P0102 - Mass or Volume Air Flow Circuit Low Input, I'm almost certain.
  8. #8 Re: Terrible stuttering/stalling problems
    TDCRacing
    Guest
    That is a Bad MAF.
  9. #9 Re: Terrible stuttering/stalling problems
    Chicago
    That is a Bad MAF.
    Since it runs perfectly with it disconnected, just slightly off at idle, should I just replace it then? Cleaning it did nothing, so I'm assuming it's more internal that just dirty.
  10. #10 Re: Terrible stuttering/stalling problems
    Banned - Busted For Scamming
    Feb 2009
    usually if the maf is giving you fits, cleaning wont help. they go bad. replace it. the only thing that sucks is its expensive like 194 bucks.
  11. #11 Re: Terrible stuttering/stalling problems
    You can get a used one just good enough from Ed.
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    Screw spending almost $200 for a sensor that doesn't even cost GM $5 to make.
  12. #12 Re: Terrible stuttering/stalling problems
    TDCRacing
    Guest
    If your looking for used, Get one from morad parts company like stated above.
  13. #13 Re: Terrible stuttering/stalling problems
    Chicago
    Emailed Ed about the MAF sensor, and he says they don't have any, and he's had plenty of trouble keeping them in. Any other places I could turn? Not a whole lot of luck on Ebay..
  14. #14 Re: Terrible stuttering/stalling problems
    GT Level Member pontiackid's Avatar
    KCMO
    Local salvage yard chain. But, make sure they have a money back policy in the event that theres doens't work either... or give them your old one :P
    On a side note w/o the MAF your MPG will drop a little and she will run a little hard. Though from experience if the motor is "shaking" hard you definatly want to check the plug wires and plugs.
  15. #15 Re: Terrible stuttering/stalling problems
    Chicago
    Quote Originally Posted by pontiackid View Post
    Yeah. Had brakes done a bit ago, and the mechanic noted that I could use new wires and plugs. Though he was horrifyingly insistent that I stick to AC Delco everything..
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. Random Stalling Problems - PLEASE HELP!!!
    By teamramrodd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2009, 03:31 PM
  3. Terrible Gas Mileage
    By TCO in forum General Tech Discussion
    Last Post: 12-16-2008, 01:01 AM
  4. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
  5. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
