Thread: Terrible stuttering/stalling problems
Results 1 to 15 of 15
  1. #1 Re: Terrible stuttering/stalling problems
    TDCRacing
    Guest
    Look first. Look by the Evap canister (little round black thing near the middle of the firewall. Should have a vacume line running to it. Make sure they are all the way pushed on. Check your spark plug wires also. If you can get the car to run spray the lines down with carb cleaner. IF you hear the idle raise you've found your leak. It's either going to be a hose that's dry rotted or a hose that is not connected properly.
  2. #2 Re: Terrible stuttering/stalling problems
    SE Level Member Chernobyl's Avatar
    Chicago
    Code was P0102 - Mass or Volume Air Flow Circuit Low Input, I'm almost certain.
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. Random Stalling Problems - PLEASE HELP!!!
    By teamramrodd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2009, 03:31 PM
  3. Terrible Gas Mileage
    By TCO in forum General Tech Discussion
    Last Post: 12-16-2008, 01:01 AM
  4. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
  5. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
