Thread: New Dyno Tune Numbers
Results 1 to 20 of 46
  1. #1 Re: New Dyno Tune Numbers
    Jun 2010
    Jacksonville Fl
    I sure would like to get some help I own a shop here in Jacksonville Florida, we had a customer bring us a 3.8 02 GTP, I do mostly Ford and use SCT, so please do not throw rocks at me, well this man had us install new heads, Nitrous and a inner cooler, now the inner cooler is not real impressive, in the first place it does not even have a reservoir, so I added one I will post pictures tomorrow, today the IAT was up there it was 95 degrees here, along with this I added Apple green 42 pound injectors, the car has a larger TB and a Cardone Maf, he bought a ECM from ZZ Perf, and we added larger exhaust, and the ECM is supposed to calibrated for the Maf, I had the TB powder coated and the S/C as well and had the VC painted all gloss black the install is perfect it really looks good, I sucked the stock file out from ZZ and made the change for 42,s but I can not get the AF straight it is a steady climb lean at WOT, so I am fairly frustrated, I will check FP tomorrow and I will solve this. I want to expand my platform to GM, and I know this takes time, but I sure need some guidance here and any help would be appreciated I thought some of you would like this, it is my daily driver it made 660 RWHP on a 75 shot with a Novi 2200.
    Here is the dyno run with the 75 shot you will love the purge shot.
    http://www.youtube.com/watch?v=uVMXxAEeI_Q
    http://www.mercurymarauder.net/gallery/data/580/DennisNovi2200.jpg
  2. #2 Re: New Dyno Tune Numbers
    GT Level Member jdmgtp's Avatar
    MI
    monster!...
    so yeah, I'd say check the fuel pressure first. Do you have a scan?
  3. #3 Re: New Dyno Tune Numbers
    Jun 2010
    Jacksonville Fl
    I was right the pump was the problem, the AF is now 11.6 so can some one tell me what a car should make on the dyno, with pump gas
    Here is the first pull on the dyno with the new pump. I know the car has more, what is the average with this setup.
  1. P0121 & poor performance after dyno tune
    By nugzo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2009, 04:11 PM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. My Dyno Tune
    By Keifer in forum General Tech Discussion
    Last Post: 07-15-2008, 07:12 AM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. Pacesetter header dyno numbers?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2008, 09:23 AM
