IIRC I think it is a Mustang dyno...
wow man, thats sick. i wish my car was that fast. how long did it take you to get all those mods into your car?
Just had my GTP dynoed today, not what I expected. 215whp/235torque. I thought I would be much higher at least 240hp to the wheels. Something is not right the car has gotten much slower this past six months. Its like driving with the supercharger belt off even though it is obviously not, the dyno setup measured 10.4 psi of boost. Has anyone ever encountered this with no codes and no KR with a "tuned by scan tune" on the car. BTW:My mods:WizAired CAI,3.5"Pulley,NGK-TR6,1.8 RR,3"DP,3"Cat&3"Exhaust.Custom PCM Tune.
What is the stock 2001 gtp put to the wheels? That would shed a light on things considerings my mods. At least I made about 50hp or more with what I have, dont you get a 15-20 hp increase with just a cold air intake, plus I have roller rockers and the exhaust mods, so something is holding the power back.
One thing though besides the tune that comes to mind is that I swapped out all my injectors with flow-matched zzp reman'd injectors when I got my LIM gaskets done and the car became alot quicker which slowly declined since last winter. So I don't know if the they are at fault but am just weighing out the variables. There are no codes or KR as I mentioned in my first post so I would think something would set if fuel was lacking to the engine which seems is not the case. So as some of us said it has to be the tune.
Sounds like a crappy dyno or a bad tune...that thing should be making more torque than that
Yeah, I'm leaning on it being something with the tune. I used to run a dhp 1.0 and it used to pick up quick but too much kr under accel & wot which meant too much timing and too lean. Thats why I went with a "tune by scan" starting with a stock bin via email. It now has no kr but as you can see it can be much better. I dynoed it a local speed shop 3 pulls @$60 weekend special event. They quoted me $320 for a 3 hour dyno tune. I'll have to put some $$ aside for that one, but the guy there said it should be no problem getting it to where it should be at with the mods I have.
stock they put down between 190-195. You don't have headers or a PEMs, 1.8 rockers don't do crap (at least not on my car). Do you have a colder stat?
You really need some headers
my car must be a torque freak im up at 371 and 281 hp at wheels with mild cam
oh ok for some reason i thought i saw more mods in there
now i gotta start modding the crown vic i have was on crownvic.net for a long while but didnt mod it much gtp took all my time
