Thread: Help!! '01 GTP misfiring/idiling rough at startup!!
Results 1 to 13 of 13
  1. #1 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    SE Level Member fatride99's Avatar
    Huber Heights, OH
    Quote Originally Posted by Zef_66 View Post
    Do you have any codes that the SES light is set on the dash? If so...what are the codes?
    But it could be a lot of things...anything from a bad O2 sensor, plugs, wires, vacuum leak, etc....Need some more info I think.
    No codes. Put a new denso front O2 in last fall when we put my tog's on. Plugs were installed last may at intense, after i got the GTP. When it does this, it goes for like 30 seconds or so, then straightens up. No issues after that, unless it sits overnight, then it does it again, then is ok. Sometimes, it starts right up w/ no issues at all. Hope that helps.
    Jason
    My Ride - '01 GTP Blue/Black (2.dr)
    1949 Mercury Coupe
    R.I.P. - '01 GT Blue/Black
  2. #2 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    PA
    Quote Originally Posted by fatride99 View Post
    Jason
    Try unplugging the MAF before you start it some morning when it is cold and see if it still does it.
    2001 GSE
  3. #3 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    hangover park IL, in the garage working on one of 12 3800's
    sounds like a possibility that the FPR is leaking fuel into the LIM overnight, pull the FPR vac line off and smell for gas/wetness.
  4. #4 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    Huber Heights, OH
    Quote Originally Posted by turbocharged406sbc View Post
    What does that look like? Is it the round disc looking part on the fuel rail? I have another fuel rail w/ fuel injectors from an '01 GTP w/ 50K on it at home, that i might swap out. I think that i'll need the tools to remove the fuel line from the rail, what's it called and where can i buy one at?
    jason
    1949 Mercury Coupe
  5. #5 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    jason
    if your refering to a 99+ rails assembly with the pulsation dampner no thats not the disk, the fuel pressure regulator has a vacum line running to it from the vac tee at the LIM under the snout, remove the vac line and smell it if it smells like gas the diaphram in the FPR is leaking, this is the same issue that causes alot the the NA 3800 engine fires since it's possile for the engine to backfire and set the fuel in the LIM on fire...
  6. #6 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    Huber Heights, OH
    I'll make sure to look at that before i start her up again.
    Jason
    1949 Mercury Coupe
  7. #7 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    PA
    Yeah, the arching is a classic sign of a bad spark plug wire. And that would surely cause a miss. Get the plugs and wires changed and see how it acts.
    Also, from the looks of it, you have headers. It is a common problem for the middle spark plug wire on the back side to rub against the header and cause it to burn and short out. When you install the new ones, make sure that all the wires area away from hot surfaces.
    2001 GSE
  8. #8 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    Huber Heights, OH
    Just replaced the maf about a month or so ago. If the maf is bad again, i'm gonna get pissed. I've got a gen.V at home w/ an ls1 tb and a SLP MAF that i might end up putting on if this continues.
    Jason
    1949 Mercury Coupe
