Thread: Help!! '01 GTP misfiring/idiling rough at startup!!
Results 1 to 13 of 13
  1. #1 Help!! '01 GTP misfiring/idiling rough at startup!!
    SE Level Member fatride99's Avatar
    Huber Heights, OH
    First off, i had an issue a month or so ago w/ the car and it was acting similiar to how it is now. Ended up being my MAF. The one on the car read "0".
    Now, it's starting to act up again. When it sits overnight or for a long period, when i start it up, the car runs rough and i can hear it misfiring. Normally, i'd just wait for 30 seconds or so, and it'd straighten out. This morning, it was doing the same thing, but worse. I had it running for a few minutes and it was actually missing more and it never straightened up. I ended up taking my other car to work. I have a new set of jacobs wires, plugs and my coil packs off of my '01 GT, which had 47k on them. I plan on changing them once it's nice enough outside. Are there any other explainations for my car running this way? Maybe another sensor or something else?? Let me know what you think. I took a video of the car from startup a few weeks ago, but it started up fine, go figure. I'll try again this weekend to post a video of it. Now, as far as the video goes, should i be right behind the car, or back about 10' or so, so that the car can be heard better? The last video, i was behind the car and you couldn't really hear how deep the exhaust is.
    Jason
    My Ride - '01 GTP Blue/Black (2.dr)
    1949 Mercury Coupe
    R.I.P. - '01 GT Blue/Black
  2. #2 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    chi-town
    i had a code for a "misfire on 3" only on occasion , sometimes go weeks without a problem , tried an injector but didnt fix , turned out to be a bad plug.
  3. #3 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    GXP Level Member Zef_66's Avatar
    PA
    Do you have any codes that the SES light is set on the dash? If so...what are the codes?
    But it could be a lot of things...anything from a bad O2 sensor, plugs, wires, vacuum leak, etc....Need some more info I think.
    2001 GSE
  4. #4 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    Huber Heights, OH
    Quote Originally Posted by Zef_66 View Post
    No codes. Put a new denso front O2 in last fall when we put my tog's on. Plugs were installed last may at intense, after i got the GTP. When it does this, it goes for like 30 seconds or so, then straightens up. No issues after that, unless it sits overnight, then it does it again, then is ok. Sometimes, it starts right up w/ no issues at all. Hope that helps.
    Jason
    1949 Mercury Coupe
  5. #5 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    PA
    Quote Originally Posted by fatride99 View Post
    Jason
    Try unplugging the MAF before you start it some morning when it is cold and see if it still does it.
    2001 GSE
  6. #6 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    hangover park IL, in the garage working on one of 12 3800's
    sounds like a possibility that the FPR is leaking fuel into the LIM overnight, pull the FPR vac line off and smell for gas/wetness.
  7. #7 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    Huber Heights, OH
    Just replaced the maf about a month or so ago. If the maf is bad again, i'm gonna get pissed. I've got a gen.V at home w/ an ls1 tb and a SLP MAF that i might end up putting on if this continues.
    Jason
    1949 Mercury Coupe
  8. #8 Re: Help!! '01 GTP misfiring/idiling rough at startup!!
    Huber Heights, OH
    Well, i started my GTP up last night (2/4). It was still idiling rough and this time, it threw a check engine light. I was taking a movie of the car, but it was too loud for my camera to pick up clearly. I did however open the hood and you'll never guess what i saw. On the back side of the motor, i saw a blue glowing light, from i assume a plug wire or plug. Needless to say, i shut the car off after that. Weather was crappy today, so i wasn't able to work on the car. I would take another video of the car arcing, but i don't think that'd be a good idea to do. I'm gonna change the wires and plugs to see if that fixes my issues and i'll keep you up to date.
    Jason
    1949 Mercury Coupe
