Thread: Horrid mpg what am i missing???
Results 1 to 20 of 22
  1. #1 Horrid mpg what am i missing???
    Apr 2009
    stockton ca
    My mpg is sitting at like 17 mpg on the d.i.c Ive changed oil changed plugs changed wires put on a new fuel filter new airfilter too
    swaped blowers due to a bad coupler and it being pretty chewed up
    Even clay bard and waxed to bring down wind resistance..(j/k)
    the car has 179xxx on it
    No codes runs decent ill say
    has minor oil leaks i have yet to fix
    I have a pc based diagnostic program
    not quite sure what to look for what normal paramiters are for these cars
    Any input would be great
    its sad that my crown vic is getting better mpg with a bad maf and cats that are beging to fail
  2. #2 Re: Horrid mpg what am i missing???
    GTP Level Member dstout's Avatar
    ky
    Could have a bad o2 sensor.....maybe?, I bought a replacement for mine just have not changed it yet....They say a bad o2 sensor will set off the SES light but I'm not totally convinced it will. What year is your car?
    Try disconnecting the battery for a while it might be something with the PCM.
    Have you done a Seafoam? You should do that before you cance the oil, the plugs should be ok after the Seafoam since they are new.
  3. #3 Re: Horrid mpg what am i missing???
    Apr 2009
    stockton ca
    havent seafoamed yet
    its a 98
    the o2s look ok from what the data logging shows
  4. #4 Re: Horrid mpg what am i missing???
    Apr 2009
    Springfield,Va
    If you do the seafoam suck it down though the boost bypass valve I wanna say. Going though the throttle body will take the coating off the rotors.
  5. #5 Re: Horrid mpg what am i missing???
    Apr 2009
    stockton ca
    good to know
  6. #6 Re: Horrid mpg what am i missing???
    ky
    If you do the Seafoam make sure you do it outside and not inside a garage cause it smokes and stinks like Hell.
  7. #7 Re: Horrid mpg what am i missing???
    Oct 2008
    Northern Illinois
    I also have a 98 GT, I thought my 17MPG was normal is that bad for our cars? lol.
  8. #8 Re: Horrid mpg what am i missing???
    Aug 2008
    Long Island, New York
    Quote Originally Posted by BwolfGT View Post
    yea my gtp is always reading around 15.6 on the DIC... i would think you are lucky with getting 17
  9. #9 Re: Horrid mpg what am i missing???
    Oct 2008
    Northern Illinois
    Try fuel injector cleanor...mine read 15.6 for months till I ran that through a few times, now it's jumped to 17
  10. #10 Re: Horrid mpg what am i missing???
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I've been upset with mine at ~23, and that's with bigger brakes, 17" wheels, wider tires, etc. I was getting 30+ when it was newer.
    2001 Buick Regal LS - Almost Stock
  11. #11 Re: Horrid mpg what am i missing???
    Aug 2008
    yea i seafoamed the car a little while back, didnt change
  12. #12 Re: Horrid mpg what am i missing???
    ky
    MAF Cleaner? Have you done that?
  13. #13 Re: Horrid mpg what am i missing???
    Apr 2009
    stockton ca
    Havent cleaned the maf yet Is it built into the throttlebody on these cars
    i Have done seafoam treatments before just not on the gtp
    I dont know I thought the gps got atleast 20-25ish mpg
  14. #14 Re: Horrid mpg what am i missing???
    ky
    I guess I should have said the MAF sensor instead of just MAF, yes that's where mine is located. There are two security screws (torx) I think, that secure the sensor to the TB. Disconnect the wiring harness and use MAF Sensor Cleaner to clean it. Don't touch the wires inside the sensor just spray it down real good and it dries pretty quickly.
    If you use an oiled air filter like K&N, the oil will goof up the sensor so you should clean it every once in a while.
    I think NAPA, Sears or parts stores will sell the security bit.
  15. #15 Re: Horrid mpg what am i missing???
    CT
    damn, I really was upset when I'm only pulling down like 22mpg. I know all highway I can get 30ish. My SES light comes on because of my O2 sensor. I got a downpipe with the O2 in it already and used that but I feel that it might be bad. We'll find out I guess.
  16. #16 Re: Horrid mpg what am i missing???
    Heh...I got 31mpg's on all of my mods with a custom tune and a 3.1" and the stock tranny...hell even with my misfire and only running on 5 cylinders I was able to squeeze 19mpg out of it on the HWY
  17. #17 Re: Horrid mpg what am i missing???
    ky
    What kind of gas do you use? just wondering
  18. #18 Re: Horrid mpg what am i missing???
    Apr 2009
    stockton ca
    supreme at chevron usually
    but nothing less then 91 octane
  19. #19 Re: Horrid mpg what am i missing???
    o2 sensor...fuel filter...plugs/wires...air filter...do that stuff
  20. #20 Re: Horrid mpg what am i missing???
    Aug 2008
    yea i gotta do that stuff as well. its on the "To Buy" list
  1. Do you see anything missing here?
    Last Post: 02-24-2009, 06:26 PM
  2. Drag racing with missing headlights?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 02-24-2009, 04:26 PM
  3. Is something missing?
    By sUpErClEaNbLaCkMaChInE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 07:56 PM
  4. Car feel like its missing under WOT?
    By lightfoot__ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2008, 02:07 AM
