I was charged 650. He is doing my alternator, the large bracket the coil packs sit on and bolts to the pass side dogbone, the same bracket that sits on the drivers side that the dogbone bolts to, Both brackets that the front of the dogbones mount to(including sanding down the raised rivet looking welds), Bolts and nuts for all the above including the nuts on my strut towers, Bracket that holds the speed cable (I believe), and another bracket that holds the throttle cable behind the SC, and finally the big black bar that braces the alternator.
