Thread: Valve cover gasket replacement
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 103
  1. #1 Valve cover gasket replacement
    Donating Users Burgundyman's Avatar
    I am trying to replace the valve cover gasket on my 1998 GTP...The problem is with the bracket the holds the belt tensioner, coil and wires in place...I need some insight in removing this bracket so that I can remove the valve cover. Any insight would help.
  2. #2 Re: Valve cover gasket replacement
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    13mm deep socket should do it.
    There are 2 studs below the coilpacks. The tensioner is on one that comes off easily enough, there's a nut in there take it off, it'll slide out. and then there are a few more nuts and a ground there. MAKE SURE TO PUT THE GROUND BACK !!!! or your car won't start ! Pretty straight foreward
    Lumpy Gen 3
  3. #3 Re: Valve cover gasket replacement
    There is a nut inside the tensioner?...It looked like a torx head...So there is only one nut holding the tensioner?...It was hard to see...One more thing...Do I need to back off the Supporting yolk brackets (two of them in the front of the rad) to get the valve cover off?
  4. #4 Re: Valve cover gasket replacement
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Unless things have changed there shouldn't be any torx heads. I don't remember the size 12, 13 or 14mm socket should slide right over what looks like a torx head.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: Valve cover gasket replacement
    Alright...I am going to give it a shot...I hate oil leaking on my block.
  6. #6 Re: Valve cover gasket replacement
    St Louis MO
    Quote Originally Posted by Burgundyman View Post
    So it's only the front one? That once isn't too bad compared to the rear vc.
    2010 Camaro SS LS3
  7. #7 Re: Valve cover gasket replacement
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^he's right!
  8. #8 Re: Valve cover gasket replacement
    Rockford, IL
    or if you cant get it drain the coolant a bit form the radiaor so the coolant level is lower...and just pull that bracket...
    just remember to top it off when everything is back together...
  9. #9 Re: Valve cover gasket replacement
    Draining the rad takes the pressure off the dog bones?...I am lost on this one...
  10. #10 Re: Valve cover gasket replacement
    St Louis MO
    he's referring to the alternator bracket and that cooling elbow. The alternator bracket is also a cooling passage way. If you don't break the elbow you won't see any coolant.
    2010 Camaro SS LS3
  11. #11 Re: Valve cover gasket replacement
    Got it....Well, this is certainly going to be a fun project...
  12. #12 Re: Valve cover gasket replacement
    Rockford, IL
    take your time!!!!!! you can do it!!!
  13. #13 Re: Valve cover gasket replacement
    St Louis MO
    ^^^ X2
    2010 Camaro SS LS3
  14. #14 Re: Valve cover gasket replacement
    SE Level Member TooMch's Avatar
    St. Louis, MO
    I'm not the biggest DIY guy but I wish I had more confidence and knowledge.
    My question is:
    Where should you have the transmission with either of the tilt engine techniques?
    2004 GTP CompG
    wizair| LQ4| S2IC| 3.0| 1.9RR| RS12YC| 160°| 39#|TOGX|3" Hogan DP| Corsa| tune
    2007 = 13.034 @ 103.68 (TOGX, AL103, ZZP DP)
    2004 = 14.576 @ 94.34 || 2005 = 13.822 @ 97.57 || 2006 = 13.224 @ 99.98 (PEMs,TR6IX, RT DP)
  15. #15 Re: Valve cover gasket replacement
    St Louis MO
    Quote Originally Posted by TooMch View Post
    My question is:
    According to the makers of the engine tilter (Lisle) neutral. But if doing it by the other method, it can't be in neutral.
    2010 Camaro SS LS3
  16. #16 Re: Valve cover gasket replacement
    Jan 2009
    Waddell, Arizona
    This forum saved me... I also have a leaky rear valve cover gasket in my 2000 grand prix... and I couldn't get the cover off and couldn't figure out how to get alternator brace off... Your advise to loosen and lift worked wonderfully!!! THANK YOU SOOOO MUCH for your input!!!
  17. #17 Re: Valve cover gasket replacement
    Oklahoma
    I have seen those tilter tools before, I wish I had grabbed it when I seen cause I cannot find them around here. But I have never put my car in neutral to rock the motor forward. I just pull on the blower snout and lock it in place with the dogbone.
    That said, I dont thing that way would pull it forward enough to give sufficient access or easy access to the rear valve cover. I could be wrong. When I replaced my VC gaskets I was doing a LIM gasket change also so it was kinda a mute issue.
  18. #18 Re: Valve cover gasket replacement
    Rockford, IL
    when you have the engine rocked forawrd, there should be plenty of room...as there is about 4-5inchs away from the firewall....
  19. #19 Re: Valve cover gasket replacement
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by UR LOSN View Post
    when i changed the plugs in my regal, i didnt get that much play out of tilting the engine forward...
    here's my solution, not using a tilting tool (assuming inside a garage, hopefully with wall/immoveable object close by)
    -- remove dog bones.
    use ratchet strap from wall to engine lift bracket... ratchet snug, will pull engine forward -- dont pull too much, dont want to break anything (if you havent removed the air filter box yet, do that first)
  20. #20 Re: Valve cover gasket replacement
    Oklahoma
    Quote Originally Posted by Toasty View Post
    Im going to have to go tomorrow and find me some small ratchet straps and try that out, that sounds like a perfect solution.
  1. Lets see your painted/smoothed/custom front valve cover
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:37 PM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  4. Finished Valve Cover
    Last Post: 02-01-2008, 06:10 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
