Thread: Valve cover gasket replacement
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 103
  1. #81 Re: Valve cover gasket replacement
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Nice job David. I can't wait to see everything installed. Be sure to get pics of the tilter hooked up. I have 4 pictures I took tonight, but IMO they are took dark to be useful. However since I said I would..here ya go.
    Valve cover gasket replacement Attached Images
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #82 Re: Valve cover gasket replacement
    Donating Users Burgundyman's Avatar
    Quote Originally Posted by IndeedSS View Post
    Nice pictures. Although my tilter arrived, my torque wrench is still in the mail. Can't get started on the other vc yet...Now it looks like the manifold gasket is also leaking...I figure I might as well replace it...I can't imagine where else the oil could be coming from because the front vc is tight and dry.
    Anyone replace the manifold gasket?...I see that you can get an aluminum one, which is an improvement over the OEM.
  3. #83 Re: Valve cover gasket replacement
    Oklahoma
    I replaced mine last year, but I had help (Thanks Webracin). Its a common problem for coolant leaks into the engine, so you would probably be doing yourself a favor by replacing it now and you'll get good use out of that torque wrench
  4. #84 Re: Valve cover gasket replacement
    GTP Level Member David99GTP's Avatar
    Florida
    Hmmm thats a thought since I have almost everything already off. BUT, I dont think mine is leaking. I have a very small amount of leakage around my valve covers. So that will be fixed when I install the new covers. As for the manifold, I think I'll leave that one alone. I think I already bit off more than I can chew. Taking the stuff off wasnt the hard part. Remembering where everything goes is going to be the hard part.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  5. #85 Re: Valve cover gasket replacement
    Oklahoma
    Just take your time, label everything regardless of whether you know where it goes or what it is. Clean everything like you were getting ready to do surgery. Do that and take it slow and easy and you'll have no problems.
    When me and Chris did my LIM gaskets last year we repalced those, new injector o-rings, new LIM, modular pulley system, replaced one of my axles and God knows what else. But we took our time and when we got it all back together, we had not ONE extra bolt or nut or anything and the car started on the very first try and had not ONE leak.
  6. #86 Re: Valve cover gasket replacement
    Quote Originally Posted by David99GTP View Post
    For what it is worth, I documented every step...In this way, all I did was to reverse them to ensure that I did not forget anything...Believe it or not, it worked like a charm...Of course, it took a bit longer..
    Mike at WBody store indicated that the manifold gasket leak is a common problem with the 3.8 litre motor. I think it is leaking at the front of the engine and not so much the sides. That is where the half round rubber gaskets seal.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  7. #87 Re: Valve cover gasket replacement
    St Louis MO
    Quote Originally Posted by Burgundyman View Post
    LOL I have to be more careful since it appears I'm getting Burgundyman the OP and David crossed.
    2010 Camaro SS LS3
  8. #88 Re: Valve cover gasket replacement
    Florida
    Its OK I knew you were confused. Just dont get confused on the advice
    1999 GTP
  9. #89 Re: Valve cover gasket replacement
    Florida
    Manifold Absolute Pressure sensor. If you look at your rear valve cover there is small horsehoe squared off metal bracket that holds the MAP sensor. I believe this may be in the way of you being able to remove the valve cover. The MAP is a black plastic rectangle with an electrical conenctor and a vacuum line that conenct to the underneath. I believe the same bracket holds the evap solenoid.
    If it were me I would remove the alternator bracket and replace the coolant elbow while you are doing all of this. Yes it is the 90* black elbow. If installing a new one, be sure to put a little vasoline on the orings so they slide in easily and don't pinch or bind.
    I was able to save 1 of 2 elbows. I figured it was a good idea to replace anyway. Probably brittle from being almost 10 yrs old. Went to autozone and they looked at me like a sprouted 8 heads. They had no clue, even the manager had no clue what I needed even though I had parts in hand and pictures on my cell phone.
    Went to NAPA, they knew what it was. Said same as the cadi. But they didnt have the part. Advised me to go to a dealer. Its sat almost 5pm looks like Monday
    I was able to get a lot of parts off though. I removed the engine lift brackets. Cleared up a ton of room. I think I can easily do the rear cover now.
    I'll post up pics soon. I painted the exhaust and crossover pipe with ceramic 1200 degree paint. The bay is looking sharp.
    1999 GTP
  10. #90 Re: Valve cover gasket replacement
    Florida
    1999 GTP
  11. #91 Re: Valve cover gasket replacement
    Florida
    1999 GTP
  12. #92 Re: Valve cover gasket replacement
    Oklahoma
    Keep us posted, things are looking good. Id be curious as to how that paint holds up.
    With regards to the coolant elbows. Autozone carries them, they are in the 'Help' section. They usually have them, so if you feel up to it, head there again and check it out.
  13. #93 Re: Valve cover gasket replacement
    Florida
    Maybe I'll try another location. perhaps this one didnt have a big selection. I thought maybe pep boys too.
    1999 GTP
  14. #94 Re: Valve cover gasket replacement
    Florida
    I hope the paint holds up. I cleaned and degreased before I sprayed. Good for 1200 degrees, so i think it'll be ok.
    1999 GTP
  15. #95 Re: Valve cover gasket replacement
    Florida
    1999 GTP
  16. #96 Re: Valve cover gasket replacement
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    its possible that the autozone people you talked to didnt even realize they carried those parts in the help section....
    nice lookin valve covers... though dont go usin that breather.... you'll have too much ventilation.
  17. #97 Re: Valve cover gasket replacement
    St Louis MO
    Toasty...I was thinking the same thing about AZ employees not knowing about the elbows in the Help section. I experienced the same thing and had to retrieve them myself and then point it out to the cashier.
    2010 Camaro SS LS3
  18. #98 Re: Valve cover gasket replacement
    Florida
    I hit pep Boys and found the elbows. Thanks!
    As for the breather, I shouldnt use it? What will happen? I bought it from ZZP. They only had one to select from. What should I do then, run it with the stock and throw the ZZP on for shows only?
    1999 GTP
  19. #99 Re: Valve cover gasket replacement
    GT Level Member nutcase's Avatar
    Washington State
    er...my gtp had a recall on the valve cover gasket. iI take mine to the dealer only to have the oil changed and they notified me of the recall!
  20. #100 Re: Valve cover gasket replacement
    Jan 2009
    Waddell, Arizona
    This forum saved me... I also have a leaky rear valve cover gasket in my 2000 grand prix... and I couldn't get the cover off and couldn't figure out how to get alternator brace off... Your advise to loosen and lift worked wonderfully!!! THANK YOU SOOOO MUCH for your input!!!
  1. Lets see your painted/smoothed/custom front valve cover
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:37 PM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  4. Finished Valve Cover
    Last Post: 02-01-2008, 06:10 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
