Thread: Valve cover gasket replacement
Results 1 to 20 of 103
  1. #1 Re: Valve cover gasket replacement
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    13mm deep socket should do it.
    There are 2 studs below the coilpacks. The tensioner is on one that comes off easily enough, there's a nut in there take it off, it'll slide out. and then there are a few more nuts and a ground there. MAKE SURE TO PUT THE GROUND BACK !!!! or your car won't start ! Pretty straight foreward
    Lumpy Gen 3
  2. #2 Re: Valve cover gasket replacement
    Donating Users Burgundyman's Avatar
    There is a nut inside the tensioner?...It looked like a torx head...So there is only one nut holding the tensioner?...It was hard to see...One more thing...Do I need to back off the Supporting yolk brackets (two of them in the front of the rad) to get the valve cover off?
  3. #3 Re: Valve cover gasket replacement
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Unless things have changed there shouldn't be any torx heads. I don't remember the size 12, 13 or 14mm socket should slide right over what looks like a torx head.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Valve cover gasket replacement
    Alright...I am going to give it a shot...I hate oil leaking on my block.
  5. #5 Re: Valve cover gasket replacement
    St Louis MO
    Quote Originally Posted by Burgundyman View Post
    So it's only the front one? That once isn't too bad compared to the rear vc.
    2010 Camaro SS LS3
  6. #6 Re: Valve cover gasket replacement
    That was going to be my second question...How difficult is it to do replace the rear.
  7. #7 Re: Valve cover gasket replacement
    St Louis MO
    There is a lot more to the rear one. I'm not sure the year, but on one of the GP's you don't have to remove or pull the alternator bracket out of the way. You'll have to look to see if your alternator bracket sits close and over top of the valve cover.
    Other than the alternator bracket, there is just a lot more stuff to work around and it's location makes it more difficult too. Tilting the engine forward helps a lot when working on the firewall side of things.
    2010 Camaro SS LS3
  1. Lets see your painted/smoothed/custom front valve cover
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:37 PM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  4. Finished Valve Cover
    Last Post: 02-01-2008, 06:10 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
