Thread: Can I use studs for my rockers
Results 1 to 9 of 9
  1. #1 Can I use studs for my rockers
    SE Level Member thomasj's Avatar
    Indiana
    I was wondering if its ok to use studs for the rocker arms. Here is a pic of what im thinking of using.
    These studs are
    Dorman Part # 675-201
    Black oxide coated
    150,000 PSI
    Thread A length (in head) is 5/8" with 5/16-18 thread Thats the same that was engaged with the bolts. Thread B length is 1-5/8 with 5/16-24 thread. We even offer the lock nuts for the tops so that would be extra safety against them coming loose.
    I see no reason why this wont work.
  2. #2 Re: Can I use studs for my rockers
    Barksdale AFB, LA
    Maybe that it won't clear the valve covers...?
    You need to have the longer portion of the stud going down into the head, not the shorter. Also, how do you intend to preload the studs? There's no head on the end to torque them in before applying the nut.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Can I use studs for my rockers
    Go find the dimensions for the Comp Cams re-usable bolts...then go buy them at your local hardware store.
  4. #4 Re: Can I use studs for my rockers
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    why not just order some re-usable one? they are only $20 for all 12
    ZZ Performance
  5. #5 Re: Can I use studs for my rockers
    Jan 1970
    Maquoketa, Iowa
    This really isn't any area you want to be cheaping out on or screw up on, just buy the reusable one's from zzp.
  6. #6 Re: Can I use studs for my rockers
    Not trying to cheap him out. They are reusable...in fact they are stamped EXACTLY like the Comp reusable bolts. I sat there dumbfounded myself when I stumbled upon them...$.80 cents a pop or something like that. It never hurts to save a few bucks when you really can. FYI I ran these for well over a year with no issues.
  7. #7 Re: Can I use studs for my rockers
    Barksdale AFB, LA
    My Comp Cams reusables were unique and had Comp Cams branding on them. Had no stamping other than their logo.
    I got them in my rocker install kit from ZZP. I thought it came with the OEM bolts, but mine came with the Comp Cams bolts. No complaints.
  8. #8 Re: Can I use studs for my rockers
    There is a stamp of a small set of numbers or letters at the head of the bolt. Pretty small. They matched up exactly to ones at the hardware store.
  9. #9 Re: Can I use studs for my rockers
    Barksdale AFB, LA
    Do you know what those numbers mean? Most likely it's just the thread pitch, shaft length, and the shaft diameter. How do you know the strength and temperature tolerances are the same? I would hope you at least used Grade 8 bolts.
    I don't even see the point. The Comp Cams bolts are only $20. Why not get something you know is intended for that setup? The reason they're more expensive is because of the hardening processes used since they're in a high load and high temp application.
  1. Using Studs such as ARP
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2015, 08:43 AM
  2. arp head studs?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 02:42 PM
  3. wheel studs
    By ibanez0110 in forum General Tech Discussion
    Last Post: 11-10-2008, 07:52 AM
  4. Wheel Studs....
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2008, 12:47 PM
  5. Studs
    By wrfdff4 in forum Tires & Wheels
    Last Post: 03-31-2008, 11:16 PM
